60ft times?
Yes you have to have lots of practice in YOUR car to get them the lowest ...other wise a good guide is
1.6x-1.8x in ALL WHEEL DRIVE (wrx,gsx,etc)
1.7x-1.9x in FRONT WHEEL DRIVE
I dont know of many RR in my area so.....and these are times for very good drivers
I highly doubt stock ITR's can get 60 ft times under 2.0 seconds on street tires.
[Modified by Eyewitness, 11:25 PM 6/21/2002]
Like i said with a very good driver 1.9x is possible in a FF ...a stock might not be able to do it ...but IHE and a good driver and ive seen it done many many times
Not on street tires????? easy on drag t/a's
Mattj
I don't care how good you are. Nobody is pulling 1.7-1.9 on a close stock ITR with street tires.
I pull 2.1's by riding the clutch briefly from about 5k. Its pretty easy to get a good 60'. Just rev it up and let it bog as you come off the line. The key is a good 60' that puts you in VTEC.
Thats why I've pulled a 14.0 with a 2.1 60' and a 14.0 with a 2.3. Its all about where you get it to hook up.
Yeah, no way you could pull a 1.7-1.9 on street tires. 2.1 is probably the best for an ITR.
How does an I/H/E help a 60' time????
[Modified by JohnnyBoy, 8:22 PM 6/21/2002]
i guees the cats ive seen in R's on not stock tires but street tires are just better drivers...
If they can pull 1.7-1.9's they should be in the 13's easy even if they are stock or close to it. Let me see some slips and we'll se how good a driver they are.
As in running drag radials. They're still not pulling 1.7's.
[Modified by Eyewitness, 2:14 AM 6/23/2002]
kameleon23
Apr 26, 2006 10:47 AM
sushibug
10
May 27, 2002 09:18 AM
