COmpression test need a little help
Old Oct 25, 2007 | 02:35 AM
Historyg's Avatar
Default COmpression test need a little help
Hey I need to do a compression test and its my first time, do i need a remote started, because thats what i read in my book, and should i change the spark plugs while i am doing it or will it mess up my distribution, thanks for the help
Old Oct 25, 2007 | 03:40 AM
crazyz250's Avatar
Default Re: COmpression test need a little help (Historyg)
all you do is screw the compression tester (almost like a tire pressure tester) in, and go turn the car over for a second. You can change the plugs at this time if you want, as your going to have one at a time out anyway, just make sure you put the plug wire back to the right cylinder, that is the only thing that can mess up your timing
RyanWhite
12
May 31, 2015 09:36 AM
danny98r
May 18, 2005 12:31 PM
zracer240
Apr 24, 2005 08:35 AM
BlackB18CTeg
Mar 24, 2003 08:44 PM
smslude
Feb 25, 2003 10:40 AM
