D16Y8 timing question...
Old Oct 24, 2007 | 08:29 PM
Chris83179's Avatar
Default D16Y8 timing question...
So, I tossed in a rebuilt motor on a 99 ex. All I got was a block with a head installed already. I swapped all accessories and set the timing. After all said and done, I am left with the following compression #'s"
#1 - 122
#2 - 118
#3 - 11
#4 - 88
After this test, I realized that my cam timing was one tooth off. I moved the cam clockwise one tooth and put back together. I am left with the same compression #'s, and still has trouble trying to start.
Is it possible that I bent some valves being one tooth off on the timing? Initially, I did put the motor through several revolutions by hand to ensure there was no interference. I don't know what to think other than bent valves or bad rings...
Old Dec 18, 2007 | 12:50 AM
RKSskier's Avatar
how many miles since rebuild? maybe the rings need to set?
ArtyTheKid
Dec 25, 2012 10:15 AM
KeithsDAteg
Nov 29, 2009 05:32 PM
eortizr
Sep 2, 2005 04:20 AM
W O T
Aug 24, 2005 01:45 PM
B18C5-EH2
14
Feb 8, 2005 08:09 AM
