timing belt question
Old Oct 24, 2007 | 08:02 PM
hassan21's Avatar
Default timing belt question
how do you tighten the timming belt?
mine is lose.
i need help on where you tighten it and what size are the bolts if you can help me on that one plz
Old Oct 24, 2007 | 08:44 PM
Hanmin's Avatar
loosen the tensioner, use a flathead or something to move the tensioner so the belt is tighter, then tighten the bolt. Make sure the belt isn't tooooo tight. The tensioner is usually on the smooth side of the belt rather than the teeth side, you'll see it, its a smooth circle.
You can buy a tensioner tool to check the tension, it's not called a tensioner tool, I forgot what it's called. To use it you connect it to the longest part of the belt and pull and make sure it's to the engine's specification. Run the engine for a little then go back and check it again and do it 1 more time to be on the safe side. This is optional though, you can also guess and test if the tension is good enough.
Also if the belt isn't giving you any problems, like skipping over the gears then you don't need to tighten it too much, just a little tighter than it was just to be on the safe side.
No idea what the bolt size is, just grab 12, 14, 16, and 17 and one of those should fit.
Old Oct 25, 2007 | 06:41 AM
jlicrx's Avatar
Default Re: timing belt question (hassan21)
Old Oct 25, 2007 | 08:38 AM
jdm_titan's Avatar
loosen the tensioner, take off the top cam cover after through the top w/ a coat hanger pull the tensioner upwards and tighten the tensioner and ur done. EASY.
Old Oct 25, 2007 | 08:56 AM
ThefirstPACT's Avatar
Default Re: timing belt question (jdm_titan)
If it was me I'd just do the whole timing belt and water pump while you're in there!
Dutch
MassCivicMan987
Jun 28, 2007 02:38 PM
JDMtype Eg6
Feb 18, 2007 05:45 AM
JDMs1eeper
Jan 10, 2006 04:01 PM
aerogant
Nov 23, 2003 07:34 PM
Luserkid
Apr 10, 2003 06:41 PM
