Vtec Issues in 95 Prelude SRV
I have a 95 Prelude SRV and am having vtec issues, every time vtec should engage it bogs just like there is a issue with engagement. I tested the solinoid and it seems like its working fine, opens and closes. I also tested the vtec pressure sensor and it looks fine and does what it supposed to. Does anybody have any ideas where i should look next? any ideas are good. Btw the prelude is turbocharged and running s300 Hondata and it does not throw any codes.
Modified by H22SRV at 1:12 AM 10/25/2007
i thought that too, but when i took vtec off the screen was clean. I also went through Honda service manual instructions which say to test the resistance of the solinoid. The result came back at 16.3 ohms and manual says 14-30 ohms is alright. I also tried a manual manuver but taking the solinoid and applying power and checking if valve opens and if oil flows. It seems to do so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22SRV »</TD></TR><TR><TD CLASS="quote"> Btw the prelude is turbocharged and running s300 Hondata and it does not throw any codes.
Is it tuned?
Is it tuned?
biggs2.3
Jan 14, 2005 03:23 PM
