5th gear gind
Old Oct 24, 2007 | 06:34 PM
CR3X's Avatar
Default 5th gear gind
so my 90 crx si has a problem.. it grinds everytime into 5th gear.. my friend told me its the syncros or something.. i dont have any idea so i was wondering if i could get some info on what i could do to fix it, how much it will cost, how long and how hard it will be to do.. and maby what i could do to i duno make it better? or something? haha hit me up wit some replies... thanks
Old Oct 24, 2007 | 06:46 PM
jdmrex90si's Avatar
it could be your synchros i had a grind to 3rd every time an i bought some synchro mesh from honda put it in and it went away
Old Oct 25, 2007 | 05:39 AM
CR3X's Avatar
Default Re: (jdmrex90si)
sweet uhh how much is that gona run me?
Old Oct 25, 2007 | 06:05 AM
~sp33~'s Avatar
EFB055
Its not very often 5th wears out, who hard shifts into fifth.
Do you know if your lower gears have been replaced at all? Usually they would wear out much quicker.
Old Oct 25, 2007 | 06:58 AM
Gearspeed-Performance's Avatar
Default Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">Its not very often 5th wears out, who hard shifts into fifth.
Do you know if your lower gears have been replaced at all? Usually they would wear out much quicker.</TD></TR></TABLE>
Its actually very common. Most of the time its from people who don't check their fluid levels. They end up running it low and the top gears(5ths and 4ths) heat up due to a lack of adequate lubrication. So this creates scarring and makes it difficult to shift because the parts are no longer smooth and free. I have also just plain seen them worn out! People tend to rest their hand on the shifter in 5th gear while cruising. Well that will put some pressue on the insides and wear things out over time. Crack it open and check it out
Old Oct 25, 2007 | 07:45 AM
jdm_titan's Avatar
Default Re: 5th gear gind (CR3X)
just get it done @ a shop it's cheaper and less hassle
Old Oct 25, 2007 | 08:26 AM
layedoutat0psi's Avatar
you guys say synchro mesh will help with the grinding? mine grinds into third sometimes. so im lookin for something to stop/slow that down before it gets worse?
Old Oct 25, 2007 | 08:44 AM
CRX Toad's Avatar
Default Re: (layedoutat0psi)
Only thing the will stop it is to have it rebuilt. Either way it still has and issue, synchromesh just masks the problem.
Old Oct 25, 2007 | 08:47 AM
yeah thats what i figured but i wanted to check and see if anyone had any ideas tho. thanks man
Old Oct 25, 2007 | 08:54 AM
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Only thing the will stop it is to have it rebuilt. Either way it still has and issue, synchromesh just masks the problem.</TD></TR></TABLE>
exactly
You can bandage a deep wound but sooner or later you are gonna have to stitch it up before it gets completly infected
Old Oct 25, 2007 | 11:48 AM
Braco11's Avatar
Default Re: (GearSpeedEF7)
i would try putting in the GM synchromesh friction moddified first....if it is a small grind, it should help it... if you have the the time and money though, just get it fixed.
Old Oct 25, 2007 | 12:26 PM
Ermil's Avatar
Default Re: (Braco11)
Temporarily mask it
Old Oct 25, 2007 | 01:46 PM
xanonymousx's Avatar
Default Re: 5th gear gind (jdm_titan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_titan &raquo;</TD></TR><TR><TD CLASS="quote">just get it done @ a shop it's cheaper and less hassle </TD></TR></TABLE>
Getting a shop to do it is cheaper?
Anyhow, replace your syncro before you end up having to replace the gear. Using syncromesh or something similar is just going to cover it up....it won't fix it.
Old Oct 25, 2007 | 01:56 PM
akandok's Avatar
In my friends prelude we used 10-30 mobil 1 oil and added lucas to it. That pretty much took care of the problem temporarily
brock81x
Transmission & Drivetrain
Nov 18, 2014 08:11 PM
HatchSpeeD
Aug 8, 2007 12:51 PM
DaZman69
Nov 23, 2005 01:16 PM
Marlon88
Feb 4, 2005 04:40 PM
