NEED HELP: asap.. fuel pump!!!
okay heres the thing, i was trying to hook up a switch for my fuel pump kill switch and i messed up.. the pump wire is the yellow/green line and i put that to the power and the ground to ground.. tried it out and nothing killed it, so i put the third one which was the acc to the ground and switched it and it killed the car... i try starting it back up and nothing... i look at it and basically i put a gound and positive on the fuel pump wire and blew something. located the fuel pump relay and tried two different ones and nothing. checked the fuel pump by taking it out and tested w/ a battery and it works. check light is on, but when i try to check for code it doesn't work... swapped around relays and checked all fuses and nothing..... so im stuck. what the hell is going on? did i blow something i dont know of? i also tried hooking a wire straight up to the wire where i cut from the pump, straigt over to the relay under driver dash and nothing... SOMEONE HELP ME.... it just cranks over.. did i blow the ecu???
one other thing is... check light is on, and when i try to check for the code, it does nothing. try pulling off the vtec solenoid just to see if it'll throw anything, and nope, it just sits dead on.... can the ecu be blown?
