dont remember what suspension i got....
Old Oct 24, 2007 | 03:14 PM
g0tgot's Avatar
Default dont remember what suspension i got....
hi! i got some weird silver suspension with Blue coilovers, i think its eibach....i cant tell....but do i need a special key to rais the ride height or can i adjust it manually??
Old Oct 24, 2007 | 03:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: dont remember what suspension i got.... (g0tgot)
Without knowing what your setup actually is, how can anyone accurately tell you how to adjust it?
Old Oct 24, 2007 | 04:19 PM
BlueIntegraBoy's Avatar
You can usually use a flathead and a hammer to loosen the perches if you don't have the adjuster tool. Then manually raise the perches. Lock with the flathead and hammer.
Old Oct 24, 2007 | 05:43 PM
integra racr04's Avatar
Default Re: dont remember what suspension i got.... (Padawan)
Old Oct 25, 2007 | 06:14 AM
g0tgot's Avatar
ok thanks!, it has adjuster like square NOTCHES on the discs that screw up and down, it is aftermarket still cannot determine what type....coilovers all the way around, blue colored coils, and the schock itself is grey....im thinking eibach....
Old Oct 25, 2007 | 07:14 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (g0tgot)
It should say on the spring or shock...
This is the tool you need to change the height, but the hammer way works too
Old Oct 25, 2007 | 07:47 AM
street dream gsr's Avatar
* B A N N E D *
Default Re: (St Jimmy)
liquidx
Mar 25, 2007 11:20 AM
blouto
Suspension & Brakes
Sep 16, 2005 05:35 PM
a1320addict
Suspension & Brakes
Apr 12, 2005 06:25 AM
ThatsMyEG
Nov 1, 2004 02:08 PM
