cel fuel supply system
Old Oct 24, 2007 | 02:28 PM
eh2ner's Avatar
Default cel fuel supply system
i have a 94 civic si with a b18c1.i was getting a cel 41 and 43.so i replaced the o2 sensor and i gotten rid of the cel 41 but the 43 is still coming up.where should i start to fix this?
Old Oct 25, 2007 | 07:46 AM
eh2ner's Avatar
Default Re: cel fuel supply system (eh2ner)
bump hellp plz
Old Oct 25, 2007 | 07:51 AM
importdreamer's Avatar
I may be mistaken but if the gas cap isn't all the way clicked it might do fuel supply one.
Old Oct 25, 2007 | 07:57 AM
97Ej6mike's Avatar
Default Re: cel fuel supply system (importdreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdreamer &raquo;</TD></TR><TR><TD CLASS="quote">I may be mistaken but if the gas cap isn't all the way clicked it might do fuel supply one.</TD></TR></TABLE>
That is correct. Twice ive gotten a CEL from a stupid gas attendant not putting the cap on tight enough. NJ you dont pump your own gas, lol
Old Oct 25, 2007 | 07:59 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Fuel supply code is one of the shittiest, hardest codes to pin down and fix right the first time because it's so vague.
A list of potential fuel supply problem code culprits:
Fuel pressure - regulator or pump
Fuel injectors
Fuel filter
Main relay
Oxygen sensor
Valve adjustment (buring too lean/rich due to loose/tight valves)
ECU itself
...and they're not really in any particular order. Add to that the fact that you've got an engine swap in a car and there could be another list of potential items starting with wiring, and you can see how this may be impossible to e-diagnose through this forum.
The FIRST thing to do is check the fuel pressure, or have it checked. If you're unfamiliar of how to do this it requires a special tool (fuel pressure gauge and adapter fitting to hook the gauge into the fuel filter) then take the car to shop that knows Hondas and Acuras.
The pressure should be roughly 40-48psi at idle with the vacuum hose disconnected at the regulator and pinched off - it should be 32-38 or so while the vacuum hose is connected at idle.
From there it becomes a guessing game, literally, and that sucks. I've seen a clogged/shitty fuel filter, bad fuel pump, a few bad oxygen sensors in a row (aftermarket crap), and a bad ECU all on different cars cause this same code.
Old Oct 25, 2007 | 08:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Actually a loose or even missing gas cap won't throw ANY codes on an OBD1 1994 Civic Si. That's one of those bullshit OBD2 codes.
Old Oct 25, 2007 | 09:22 AM
Syndacate's Avatar
Default Re: cel fuel supply system (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Fuel supply code is one of the shittiest, hardest codes to pin down and fix right the first time because it's so vague.
Fuel injectors
Fuel filter
Main relay
Oxygen sensor
ECU itself
From there it becomes a guessing game, literally, and that sucks. I've seen a clogged/shitty fuel filter, bad fuel pump, a few bad oxygen sensors in a row (aftermarket crap), and a bad ECU all on different cars cause this same code.</TD></TR></TABLE>
Agreed 100%.
The fuel supply system code (43) is the biggest pain in the ***, ever.
Like B18C5 said tho - first step is to check your fuel pressure .
I sold my '95 EX and it was still tossing a 43 with no noticeable effects (good fuel pressure, in range), new fuel filters (both), not short on power, not low on mpg - I couldn't figure it out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
That is correct. Twice ive gotten a CEL from a stupid gas attendant not putting the cap on tight enough. NJ you dont pump your own gas, lol</TD></TR></TABLE>
That may be correct for you as judging by your SN you have a '97 (OBD-II) but for a '94 (OBD-I) like he's got he won't see anything of a CEL what-so-ever for not tightening his gas cap all the way.
Old Oct 27, 2007 | 09:17 AM
Default Re: cel fuel supply system (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
That may be correct for you as judging by your SN you have a '97 (OBD-II) but for a '94 (OBD-I) like he's got he won't see anything of a CEL what-so-ever for not tightening his gas cap all the way.</TD></TR></TABLE>
My bad, didn't mean to give the wrong info. I didn't even take obd into consideration.
Old Oct 29, 2007 | 11:01 AM
eh2ner's Avatar
thanks for all the input will do
Old Nov 10, 2007 | 08:03 PM
Jdmsolutions's Avatar
i just did a b18 swap in a 90 hatch we started it up or the first time and cylinder 4 is barely hitting it has 160 compression its getting fuel, i just put in a walbro pump and it has a brand new o2 sensor and fuel filter and its pulling up code 43?
WHATS WRONG! IM TAKING ANY IDEAS
Old Apr 18, 2008 | 10:22 AM
HeikDiesel's Avatar
Default Re: cel fuel supply system (Jdmsolutions)
bump because I saw some good info in this thread. I'm also throwing a 43, 26mpg around town on a obd1 gsr swap, had one time the car stumbled but other than that runs perfect, good fuel pressure. There has to be a way to diagnose this rather that just throw parts at it. Any more info fellas? I read my helms and it didn't help much
Old Apr 28, 2008 | 01:48 PM
grey_ghost's Avatar
Default Re: cel fuel supply system (HeikDiesel)
my stock b20b is now randomly thrwing a 43 and 16 (fuel injectors) i would really like to know where to begin b4 i juss start buyin new injectors and all that....
Old Sep 19, 2008 | 08:27 AM
HeikDiesel's Avatar
Default Re: cel fuel supply system (grey_ghost)
Does honda make a troubleshooting chart for this CEL?
Old Sep 27, 2008 | 12:44 PM
crx378's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">Does honda make a troubleshooting chart for this CEL?</TD></TR></TABLE>
fingers crossed that they do....
Old Oct 1, 2008 | 07:14 AM
Mrmatt3465's Avatar
Default Re: cel fuel supply system (crx378)
Mine threw me a CEL 43 when I was super low on gas. After I filled it, it was gone for a few days. It threw me a Fuel Supply System CEL on my way to work this morning. =[ I'm on a stock 95 EX. I'm gonna go have my fuel pressure checked and see how that turns out. Thanks for the info guys.
Old Mar 12, 2009 | 03:14 PM
B18c1_turbo's Avatar
1992 civic hatchback 94 gsr.
i have a code 43 only when i set the rpm at 2000 and hold it for a while then it shows up but after that when i shut the engine off and turn it back on its gone. Is it because i am running a 1993 ls ecu? I have a 1994 Gsr in a hatchback. My gas is also low to may that be why?
91blackEF
Apr 5, 2021 03:23 PM
flipldls
29
Jul 12, 2010 06:05 PM
19cIvIc94
Mar 2, 2009 12:03 AM
str8JDMteggy
Jan 28, 2007 11:23 PM
punkracer
Oct 29, 2004 10:22 AM
