Need Help 00 CIVIC too much fuel...
OK.
Heres whats happening I had a pretty nice ek, turboed and a bunch of other stuff done to it. Then I got out of the honda game for about a year and the car stood in my garage. Now, I decieded I want to get rid of the turbo for better gas milage, and perhaps sell it. I removed the turbo, installed new oil pan brought everything back to stock. installed oem fuel pump, injectors, ecu. basically stock. Now my problem is when I try to start it it won't. It turns over but the engine gets flooded with fuel. If I take out the injectors, just pull them out of the manifold and then try to start it, it starts only 1/4 of fuel from the injector spray is making into the cylinder. I've tried replacing the injectors, ecu, fpr.
if you take out the turbo and just run it like that, then you HAVE to tune it.
since you had a turbo in there(i assume that you got it tuned) the ECU is sending more gas to the injectors cuz of the extra air that is going inside the chamber. have it tuned again to reduce the amount of fuel
everything went back to stock, the ecu, the injectors, i used a p28 before, now its back to stock, i took out the resistors out of the fuel lines, everything is stock.
literally everything is back to stock, except I put in a y8 manifold, and i had that in there before i turboed and when it was turboed i was using a skunk2 and now i put everything stock back on.
Re: Need Help 00 CIVIC too much fuel...
Yah, I still can't get it started, today i checked the check engine light, it ran a code 14 ivac. I replaced the ivac and checked all the wiring to it and all the tubing and it all looked fine, but the car is still getting to much fuel i replaced the fuel pump again and still no engine start I have spark, I have fuel, but it just wont start.
god damn ppl cant read these days, he said everything is back to stock, meaning everything, to the op, i dunno wut ur problem is, srry.
yep stock injectors, I already had the injectors tested they are fine I've been working on hondas for like 6 years and my dad is a honda mechanic and I have no idea whats wrong I've replaced every sensor I could think of, my last attempt before a full swap is that I'm going to replace the wiring harness, mabe theres something wrong with the wiring, i just don't want to swap the engine because this one has like 27k miles on it .
Teluan
08-29-2001 09:04 PM
