Issues after Complete Rebuild-- No turn signals?
Well, basically after a complete rebuild of my teggy-- couple things still don't work:
Turn signals-- I guess I'm missing the relay-- but not sure where it might go, maybe somewhere under the dash??
Interior Dash lights--- cluster doesn't light up, I don't have the dimmer switch, maybe I need to just need to splice the wires back together to make it work.
Um, I guess thats it? Anyone have any help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator »</TD></TR><TR><TD CLASS="quote">Interior Dash lights--- cluster doesn't light up, I don't have the dimmer switch, maybe I need to just need to splice the wires back together to make it work. </TD></TR></TABLE>
Umm... Get a dimmer switch?
I think the turn signal relay is located in the engine bay fuse box, but if not I know I have seen some hondas with the relay located on the backside of the driver side under dash fuse box...and I also believe that you need the dimmer switch hooked up in order to make the dash lights work. I guess you could just splice them, but dimmer switches aren't too awful expensive. Good luck!!!
Silvertune
11
Apr 15, 2012 09:20 PM
TwoKSiR
May 11, 2009 06:02 AM
