Painting car with Spray Can
Old Oct 23, 2007 | 06:46 PM
matmcg's Avatar
Default Painting car with Spray Can
So i just got my front end on my integra replaced and it was a mismatch of colours , along with the rust fixed on the rear quarters.
I decided i would paint my car using Dupli Color spray paint I chose midnight blue
So far i havnt added any color to the car I have only sanded the front bumper fender and driver door and sprayed on Sandable Gray rust primer.
CAN SOME ONE PLEASE GIVE ME SOME ADVICE
i would like this car to turn out as best looking as it possibly can. So any steps you could help me know would be greatly appreciated
Old Oct 23, 2007 | 07:48 PM
shad0wslay3r's Avatar
good prep work..? there isn't really much to do when you are using duplicolor, other than knowing how to spray out of a rattle can. prep will be key in it turning out as good as a rattle can job can.
Old Oct 23, 2007 | 08:33 PM
matmcg's Avatar
Default Re: (shad0wslay3r)
should i be wet sanding the dupli color after its dried? and then spraying on the clear coat out of the can and buffing it
Old Oct 24, 2007 | 03:56 AM
WihaSi's Avatar
Default Re: (matmcg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">should i be wet sanding the dupli color after its dried? and then spraying on the clear coat out of the can and buffing it</TD></TR></TABLE>
No, don't wetsand your base coat. I would assume painting your car with spray paint would be the same method as getting it done the right way.
Old Oct 24, 2007 | 11:26 AM
DC209's Avatar
Default Re: Painting car with Spray Can (matmcg)
you should just spray out of a gun they sell some cheap ones if your on a budget i think it would come out much better i personall use my paint gun but before i was doing it that way i did a spray can job and its not that easy like people make it seem and its not the same like primer but good luck and hope it comes out ok and try not to blotch it up you will notice once its done
Old Oct 24, 2007 | 11:41 AM
kelviiv's Avatar
Default Re: Painting car with Spray Can (DC209)
hey
what kind of gun do you use
i am about to paint my whole car but i'm not sure what gun i should purchase
i'm using shopline ppg
retro23
Paint and Body
10
Jul 6, 2007 03:42 PM
mustang5.slow
Paint and Body
13
Jul 5, 2007 09:04 PM
98savage
Paint and Body
May 14, 2007 04:49 PM
johng
13
Feb 17, 2005 12:43 PM
Old_Honda
Nov 2, 2004 05:16 PM
