can i mixmatch rings and pistons from diff companies??
i have 84mm cp pistons and am looking to get a new set of cp rings, but im having aweful difficulty. can i run rings from another company if they are the same bore size? at this point i need to get my car back together because my daily driver is in need of some serious work and i cant take it apart currently
Most all of the pistons use the same dimension rings.Shouldn't be any problem unless it has a custom ring pack.The aftermarket company's ring packs are mostly Hastings and Sealed Power combinations anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ »</TD></TR><TR><TD CLASS="quote">Call up the guys at camp1320, they sent me out a set of rings for 1 piston when i chipped on the instal. they got them out to me next day air
been calling for 2 days, it either is busy or no one picks up
[QUOTE=redzcstandardhatch]sounds like you need to head to the parts store!
good luck[/QUOTE
i dont have a parts store.
can i mixmatch the companies?
good luck[/QUOTE
lol autozone gets enough of my buisess, with the replacement axles and all.
called up laskey racing, and all is well. rings are on the way
i can see why you shouldnt be able to mix and match rings between brands of pistons. As long as your end gap is within spec, you should be fine...
bump because i want to know if all rings are the same between piston companies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">i have 84mm cp pistons and am looking to get a new set of cp rings, but im having aweful difficulty. can i run rings from another company if they are the same bore size? at this point i need to get my car back together because my daily driver is in need of some serious work and i cant take it apart currently</TD></TR></TABLE>
I have the total seals in a 84mm in stock... $90 Shipped with the free overnight. Send me a pm if interested.
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch »</TD></TR><TR><TD CLASS="quote">no autozone or pepboys? they sell great rings...68 bucks a set!
Seriously...you can run a set of 81.5mm rings from whatever brands they sell, and it'll work for an aftermarket forged piston?
yeah..wouldnt b20 pistons rings work? maybe not... i didnt think much about the size..
they sell some decent rings.. the size (thickness) should be the same as factory stuff. obviously hes better off, with big pistons, going with CP stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
yeah but im 84mm. didnt think about oe b20 rings.
either way i got some cp rings from laskey racing, shipped from cali to ny in 2 days
</TD></TR></TABLE>yeah but im 84mm. didnt think about oe b20 rings.
