Is it okay to run 18degrees advance daily ?
Old Oct 23, 2007 | 04:01 PM
redDAinteg's Avatar
Default Is it okay to run 18degrees advance daily ?
I had just set my timing and set it to 18 instead of 16. Is there anything wrong with running 18 degrees advance daily? This is a b18c and I run 91octane all the time.
Old Oct 23, 2007 | 04:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: Is it okay to run 18degrees advance daily ? (redDAinteg)
That's perfectly fine. 18 degrees BTDC is within the factory recommend spec range.
Old Oct 23, 2007 | 04:04 PM
Dogginator's Avatar
Daisy... Daisy...
That is within spec. The knock sensor would cause the ECU to intervene if there was a problem (GSR and ITR only). My 97 GSR has been that way for years. You should be fine.
Old Oct 23, 2007 | 04:17 PM
redDAinteg's Avatar
Default Re: Is it okay to run 18degrees advance daily ? (Dogginator)
alright thanks guys for the fast responses.
Old Oct 23, 2007 | 04:27 PM
omnirage's Avatar
Not to knock you, but are these gains worth it? I've always wondered about this.
Old Oct 23, 2007 | 04:40 PM
Padawan's Avatar
Darth ModerVader
Default Re: Is it okay to run 18degrees advance daily ? (omnirage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omnirage &raquo;</TD></TR><TR><TD CLASS="quote">Not to knock you, but are these gains worth it? I've always wondered about this.</TD></TR></TABLE>
Advancing the timing is free, so there's no reason why it wouldn't be "worth it". The only issue is the fact that certain dyno charts have shown the ideal setting on a particular motor wasn't necessarily the most advanced (in other words, 18 degrees made a bit less power than, say, 16 degrees). Furthermore, the gains involved are quite minor, and likely fall within the natural variations between dyno runs.
patrick4588
Jul 1, 2007 06:22 AM
AnAccordIsForever
Jan 24, 2006 11:13 AM
tss201secreto
12
Sep 7, 2005 09:07 PM
toooslow
Apr 24, 2003 04:24 PM
batboyvaj
Jul 29, 2002 03:33 PM
