Front strut bar
a sequence of loosening and tightening bolts.
you'll need the front control arms for the mounting points for the sway bar.
a sway bar
bushings
hopefully you've put a new exhaust on your car, cause you'll be undoing the bolts on it.
i think you have to drop your linkage too, or maybe i just did that since i was down there to retighten it.
it's pretty easy as long as you've had all those bolts apart somewhat recently.
a sway bar
bushings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">a sequence of loosening and tightening bolts.
a sway bar
bushings
it's pretty easy as long as you've had all those bolts apart somewhat recently.</TD></TR></TABLE>
forget to read???
yes the si strut bar will fit your 200 ex, you may need to drill out 2 holes on the strut tower on both sides. some are pre drilled
then you need nuts and bolts
i used 4 dizzy bolts and found some nuts laying around
a sway bar
bushings
forget to read???
