HELP MY CAR WONT START!
Old Oct 23, 2007 | 01:45 PM
custom session's Avatar
Default HELP MY CAR WONT START!
ive got a 95 hatch dx 5spd. It ran fine and then i parked it up for a week cause im trying to sell it and now i go to start it cause some one is gonna check it out tomorrow and it wont start. All the lights and cd player comes on, and the car turns over when you turn the key but it never comes to life and starts up. you just get this chugging noise as the engine tries to start.
the car has like 230k miles but it drives/drove great, has new battery, spark plugs and wires...
please if there is anything i can check or do to eliminate what could be wrong please let em know. thanks
Old Oct 23, 2007 | 03:40 PM
EJmugen's Avatar
Default Re: HELP MY CAR WONT START! (custom session)
does it have gas?
Old Oct 23, 2007 | 03:44 PM
Johnny Ricer's Avatar
Default Re: HELP MY CAR WONT START! (EJmugen)
lol does it?
Could be a bad ground, Maybe a bad dizzy, Fuel pump taking a ****, Or you have no gas.....did it start run for like a second then die at all?
Old Oct 23, 2007 | 04:02 PM
its got plenty of gas, all cables and such look fine. nothing is rotten or bad, battery is new, the leads are new, and ive had it parked for like a week, and today i went to start it and it cranks but wont start.
whats a dizzy?
Old Oct 23, 2007 | 04:03 PM
oh and i can also hear the buzz of the fuel or what ever it is, before you turn the key all the way, so i guess thats good.
Old Oct 23, 2007 | 04:04 PM
Default Re: (custom session)
dizzy=distributor
Have you checked to see if your getting spark?
Old Oct 23, 2007 | 04:11 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (soundpsych)
check if you are getting a spark if not it could be your coil pack.
around45$
???are you getting a check engine light?
Old Oct 23, 2007 | 04:18 PM
no check engine light. could it be the starter? the car IS turning over (making the chugging noise like it wants to start but just doesn't) could that be from the starter? cause ive had slow starts before in the past even with the new battery.
also how do i check and see if im getting a spark?
Old Oct 23, 2007 | 04:33 PM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by custom session &raquo;</TD></TR><TR><TD CLASS="quote">no check engine light. could it be the starter? the car IS turning over (making the chugging noise like it wants to start but just doesn't) could that be from the starter? cause ive had slow starts before in the past even with the new battery.
also how do i check and see if im getting a spark? </TD></TR></TABLE>
pull out a plug wire and put a screw driver in there close to touching the piece on the inside of the plug then put it near a ground/bolt
Old Oct 23, 2007 | 05:56 PM
are you referring to the distributor that i should put the screw driver in?
Old Oct 23, 2007 | 05:58 PM
vlc92189's Avatar
it sounds like your ignition coil inside of your distributor
its like 7 bolts, including the distrubtor cap and rotor.
Old Oct 23, 2007 | 06:37 PM
No hes reffering to the spark plug wires the section that plugs onto the spark plug.
Old Oct 23, 2007 | 06:44 PM
okay so i pull off a spark plug wire and put a screwdriver really close but not touching the metal piece on the inside of the plug ? and then touch it to the ground wire ? should i see a spark i guess?
Old Oct 23, 2007 | 06:55 PM
You stick the screw driver int the center against the top of the plug without touching the sides then hold it close to the ground wire on the block of your engine and you should see a spark. or just unplug it and hold the wire whi,le turning over the motor if you feel the jolt that cylinder is getting spark.... Thats the easy painful way and how i do it.
Old Oct 23, 2007 | 07:05 PM
okay i know im being retarted but when you say plug are you referring to the "spark plug" or the "plug wire" thanks
Old Oct 24, 2007 | 11:12 AM
clarify ?
Old Oct 24, 2007 | 11:44 AM
do i have to have the ignition turned to on?
Old Oct 24, 2007 | 01:16 PM
yes we are speaking of the wie plug you need another person turning the motor over while you do this.
Old Oct 28, 2007 | 04:50 PM
i know its a been a few days but i pulled a wire off and put a screw drive close to it when turning the car over and yes a spark arched to the screwdriver ( and hurt lol ). so i guess the distributor is working. i only tested one wire partly cause someone told me that if one is working they are all working and partly cause it hurts. is it true that if one is working they are all working? and if i need to keep testing how can i do it without hurting myself? thanks
Old Oct 28, 2007 | 05:26 PM
si_motor_spt's Avatar
"oh and i can also hear the buzz of the fuel or what ever it is, before you turn the key all the way, so i guess thats good. "
Well is the buzz noise quite or does it get louder ever time you try to crank it? If so, Your fuel pump could've craped out....When was the last time you checked your fuel pump? Try diagnose or maybe change ur fuel pump dude...........
Old Oct 28, 2007 | 05:36 PM
fuel pump i think is fine. it doesn't sound odd or has it gotten louder with each attempt.
since the car was fine before i parked and it left it for a week what could go wrong while not moving at all? i thought for sure it was the distributor but im getting spark.
Old Oct 28, 2007 | 05:41 PM
civic_driver's Avatar
intuition makes me want to say it's fuel related. could be spark as well though.
Old Oct 28, 2007 | 05:44 PM
well i only tested one wire for spark cause it shocked me and i was told if one works they all are getting spark.. this true?
Old Oct 28, 2007 | 09:13 PM
b16bluva's Avatar
Well if one does work they all should work. it has a distrubtor(however you spell that ****). Unless the other contacts are corroded and that one isnt???but the chances of that are pretty low. You can usually rent stuff from your local autozone. I would try fuel pressure gauge and check the pressure... and vacuum leaks... Pull the spark plugs what do they look like? turn the motor over with the plugs out can you smell fuel?? turn the motor over does if like it spinning fast. take off the oil cap see if the cam is spinning.. when was the last time the timing spelt was serviced.. so i guess thats all i got today.. Is that motor coil on plug. Is there oil in the wires if soo
Old Oct 29, 2007 | 03:42 AM
but how could the timing belt break just sitting there if it was running perfectly before hand ?
dbailey
18
Jan 4, 2007 01:35 PM
zach1288
Nov 16, 2006 12:20 PM
civic efb16
Aug 8, 2005 09:00 PM
gaydm.accord
Mar 30, 2005 06:20 PM
posterchild
Jun 26, 2004 02:09 PM
