B18c5 rod and cap questin
Old Oct 23, 2007 | 10:44 AM
r1de4life's Avatar
Default B18c5 rod and cap questin
So i put new rod bearings and main bearings in my motor and i have je pistons on stock rods, when i torque dow the rod bolts im able to slide them back and forth on the crank, is this because my crank was machined previously and i need oversized bearings? also if thats the case does that mean i need new main bearings also? and am i supposed to put engine assebly lube on both sides f the bearings? Thanks
Old Oct 23, 2007 | 03:17 PM
4g hatch's Avatar
Default Re: B18c5 rod and cap questin (r1de4life)
its supose to do that some. look in your service manual for rod end play,check it with feeler gauges. did you plasticgauge the bearings?
NJIN BUILDR's Avatar
You need to measure your clearances with either guages (mic.s and bore guage) or plastiguage.You only use lube on the surface between the bearing and the crank.
Old Oct 23, 2007 | 06:40 PM
4g hatch's Avatar
Default Re: B18c5 rod and cap questin (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">You need to measure your clearances with either guages (mic.s and bore guage) or plastiguage.You only use lube on the surface between the bearing and the crank.</TD></TR></TABLE>
yeah its always a good idea to have everything checked over by a machine shop if down time is not a issue,as most of us dont have the tools to blueprint with.
AssPenny
13
Feb 22, 2014 07:51 AM
jakscivic
Feb 21, 2013 08:27 AM
96redgsr
11
Dec 29, 2005 01:19 PM
rocket_R
May 13, 2005 09:19 AM
