H4 and 9006 headlight bulb difference.
Old Oct 23, 2007 | 07:57 AM
roller3804's Avatar
Default H4 and 9006 headlight bulb difference.
As far as I was concerned the only difference in h4 and 9006 bulbs is the harness. The mounting ring is exactly the same right?
Old Oct 23, 2007 | 01:30 PM
REDLUDE4WS's Avatar
Default Re: H4 and 9006 headlight bulb difference. (roller3804)
9006 bulbs are single filament bulbs rated @ 80 candle power. h4's are double filament bulbs rated @ 83 candle power on low and 138 on high. what are you plpanning on doing? slapping these in place of stock?
Old Oct 23, 2007 | 01:33 PM
roller3804's Avatar
I am getting an HID kit that is 9006. I have JDM headlights though which are H4. I believe it will go in with no mods. Just checking around to see if anyone advised against it
Old Oct 23, 2007 | 01:34 PM
94Vtecluder's Avatar
Default Re: (roller3804)
iirc they mount into the headlight differently too
Old Oct 23, 2007 | 01:39 PM
REDLUDE4WS's Avatar
they are definately different bases on the two bulbs h4 is much wider
Old Oct 23, 2007 | 01:43 PM
roller3804's Avatar
good thing I didn't buy the kit before I checked then.
Old Oct 24, 2007 | 10:12 PM
herovueboi's Avatar
Yeah, you'd have a field day finding out that they don't work with each other.
90crxdxb16
Lighting
Feb 23, 2015 10:26 AM
rjb8806
Apr 13, 2013 10:51 AM
M-benz
Sep 7, 2012 10:08 AM
JDMishEK
Lighting
Nov 30, 2007 08:05 PM
jdmkid_82
May 23, 2006 02:43 AM
