dc2 jdm front end ?
im doing a jdm front end on my 95gsr and already have the rad support in but the passenger side headlight wont fit in without hitting the abs. now of all the threads i have read about doing type r front ends i have never seen anything about having to move or remove the abs. anybody know whats up with this
From: Dont say my car is topless say the titties is out
You may have to search to verify this, but the jdm R's didn't have abs. I also heard that the 98+ integras came with a smaller abs unit, which allows the h.i.d headlight to fit without removing the unit. Hope this helps
Probably didn't want to post it here. Your best bet would be in a forum like https://honda-tech.com/zeroforum/6.
also does anybody know for sure 100% the wiring order cus i have read a couple of different things regarding how the light should be
like:first click should turn on your city lights
2nd click the low beams should come on with the city light's also on
then you can flip the high beam on and the high, low's and the city lights will be on.
I have my foglights wired to the jdm switch.
the corner lights and the sidemarkers should come on when you hit the turn signals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usagi Yojimbo »</TD></TR><TR><TD CLASS="quote">You may have to search to verify this, but the jdm R's didn't have abs. I also heard that the 98+ integras came with a smaller abs unit, which allows the h.i.d headlight to fit without removing the unit. Hope this helps</TD></TR></TABLE>
you are correct
you going to have to switch to a 98-01 abs
you are correct
dang that sux i wish i would have known that before i started this i would have got one....owell i think we are gonna just try and modify the bracket and make some room we only need about a half inch or so....then it will fit just fine
bgood7061
Jun 30, 2004 03:23 PM
bgood7061
Jun 30, 2004 02:59 PM
