jdm type r front end ?
im doing a jdm front end on my 95gsr and already have the rad support in but the passenger side headlight wont fit in without hitting the abs. now of all the threads i have read about doing type r front ends i have never seen anything about having to move or remove the abs. anybody know whats up with this
yea the thought had crossed my mind but if i dont have to i dont want to.....also does anybody know for sure 100% the wiring order cus i have read a couple of different things regarding how the light should be
like:first click should turn on your city lights
2nd click the low beams should come on with the city light's also on
then you can flip the high beam on and the high, low's and the city lights will be on.
I have my foglights wired to the jdm switch.
the corner lights and the sidemarkers should come on when you hit the turn signals.
if u hav ehte hid's then u need to 1) remove your 94-97 abs completely or 2) get a hold of the 98+ abs and install it to clear the ballast and there 3 move your existing abs to get it to fit. if u got the non hid setup then it suppose to fit fine with the abs there. the wiring doesnt matter unless u really **** on the correct order. i have my city lights connected to a fog switch on my armrest then the fogs to another fog switch where my cruise switch used to be, first click parking lights, second lows, and then highs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orion840 »</TD></TR><TR><TD CLASS="quote">my boy figured out a way around it and still kept the stock abs</TD></TR></TABLE>
Mind sharing? pics?
Mind sharing? pics?
The 98+ Integra's had different/smaller ABS units. That was the same year the JDM models where fitted with HID headlights. Hence, 98+ JDM HID headlights will have issues with 94-97 model Integras with the larger ABS units.
But props to getting the HID versions. I've always wanted those.
You can most likely scratch the idea of converting to 98+ ABS. The differences are quite numerous, including a different pump/modulator unit, different master cylinder, different hard line and line routing, possibly even a different ABS computer. Most likely there are different electrical connections between the ABS and other components that you might never find.
The only possibility would be to have a 94-97 ABS wiring diagram and a 98+ diagram side-by-side, along with a donor car that you could pull all the ABS-related components from.
Otherwise you need to push your existing ABS unit back a bit, or remove it altogether and get RS Integra brake lines and prop valve.
naw its cool we are gonna make it work its kinda cool how we did it really simple just relocate the ballest and the bang more then enuff room i will post up pics....cool thing is it didnt require a fab to the abs stuff
hmmm this could be rite what u stated. im not sure tho, but my friend did his with the 98 abs and he "claims" he just bent the lines to get it to fit and that was all he did. i dunno. i guess i should do more research on this cuz im about to convert my new teg i just got. ill let u know whati find out in a few days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myfirstdc2 »</TD></TR><TR><TD CLASS="quote">hmmm this could be rite what u stated. im not sure tho, but my friend did his with the 98 abs and he "claims" he just bent the lines to get it to fit and that was all he did. i dunno. i guess i should do more research on this cuz im about to convert my new teg i just got. ill let u know whati find out in a few days. </TD></TR></TABLE>
Well I hope he was extremely careful when he "bent" the lines. One kink and he's SOL....
oh yea i have another ? but its none frontend related. is the stock white i have on my 95dc2 the same as the s2000 white...i read somewhere that they are both grandprix white but i wasnt sure
ok i got everything on and it looks great but the after marketlip that i bought from jdmshit doesnt fit its about a half inch short guess i should have just paid the extra cash and went with oem. so does anybody know anyone thats selling an oem lip or a poly lip that u know for sure will fit.
ok i think i found one from l0wboost.JSP he is a member here on honda-tech but does anybody know anything about this guy like is he straight or what
da6er
Feb 11, 2005 06:05 PM
