H-BEAMS VS I-BEAMS
Has anybody out there experience a difference bettween eagle rods H-BEAMS and I-BEAMS , i'll be doing an all motor set up , using LS crank on a gsr block im trying
to decide what rods to use, i read good things about I-BEAMS rods ,but i would like
to hear from somebody that has experience both or at least has seen both setups on some motors, i want to be safe for 9200rpm ,i'm taking care of the rest of the stuff,cams, valves, dual springs,cometic hd,headstuds,cranck balance and micropolish ,etc.etc., but i'm concerned about rods ,any experienced comments will help
yes when i inquired about the difference to Import Builders they told me their I-Beams had been used in multiple 500whp+ builds so i am sure that the eagles can handle any NA setup you throw at them. a properly sized throttle body and portmatched manifold can flow just as well as 52mm ITB's btw
The I beams are built for NA vehicles weight savings etc as mentioned above, the H beams are for more of forced induction, they are stronger but the I beams will be fine for an NA setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bignel00 »</TD></TR><TR><TD CLASS="quote">why would you use a LS crank on a gsr block?
longer stroke its 89 mm compared to 87 i think i dont remember lol but i know its a longer stroke thats why ls's have more low end torque
</TD></TR></TABLE>longer stroke its 89 mm compared to 87 i think i dont remember lol but i know its a longer stroke thats why ls's have more low end torque
b.d.racing
13
Dec 19, 2005 11:17 PM
persianprelude
32
Nov 28, 2004 09:41 PM
