newb question : GSR Head on LS
Would this be a simple bolt on or is there any sort of modifications needed, for example the vtec solenoid. Im a complete noob on this im guessing i need a new ECU but what else ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez »</TD></TR><TR><TD CLASS="quote">Would this be a simple bolt on or is there any sort of modifications needed, for example the vtec solenoid. Im a complete noob on this im guessing i need a new ECU but what else ?</TD></TR></TABLE>
Yo bro, research LS/VTEC.. can be a sweet set up.
No it won't be a direct on setup. That's the ls/vtec way you are talking about.
well what i was thinkin is of just putting a GSR head on a LS block, but now that i rethink wont it need a ECU to run it since its a bit diffrent other than that im guessing it need more things. Or will it work if i just put a GSR head on a LS and replace ECU ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreez »</TD></TR><TR><TD CLASS="quote">well what i was thinkin is of just putting a GSR head on a LS block, but now that i rethink wont it need a ECU to run it since its a bit diffrent other than that im guessing it need more things. Or will it work if i just put a GSR head on a LS and replace ECU ?</TD></TR></TABLE>
dude, dont just throw a GSR head and ecu on your Ls block, you wont make it out the driveway...just research for Ls/Vtec and learn how to do it right
I requested a short story for a title.
