best pistons for an ls-v build
depends on what your trying to do..i'm a little confused you said b16 but you also said lsvtc...so i'm assuming thats the head your runnin..what kind of cp ratio your going for...?....u gonna boost or n/a
this may help
click me alittle more info and pics
hese are the CORRECT compression Ratios for using a CTR pistons in different B series engines. note the compression on a LS vtec with a GSR head.
For Reference:
STD=Standard Bore
OS=a .25 OVERBORE
P72=GSR head
PR3=B16 Head
PR3 head/B16 Block
STD = 11.643438609136867
.25 OS = 11.703231023151065
PR3 head/B17 Block
STD = 12.193487116069006
.25 OS = 12.256369577319077
PR3 head/B18C Block
STD = 12.58636786521145
.25 OS = 12.649248792586258
P72 head/B18C Block
STD = 12.924594026551906
.25 OS = 12.989047869209281
PR3 head/B18A/B Block
STD = 12.825536009218106
.25 OS = 12.88971493738735
P72 head/B18A/B Block
STD = 13.170743903246784
.25 OS = 13.236528215133324
All calculated using OEM 3 layer gasket @ .026 and the compression height
this may help
For Reference:
STD=Standard Bore
OS=a .25 OVERBORE
P72=GSR head
PR3=B16 Head
PR3 head/B16 Block
PR3 head/B17 Block
PR3 head/B18C Block
P72 head/B18C Block
818SpoonITR
15
Feb 13, 2009 11:51 PM
speedracer209
Aug 17, 2006 01:10 AM
92integraVTECgsr
Mar 27, 2006 08:09 AM
aser1z
Jun 5, 2005 03:57 PM
