Dented header. How much power loss?
theres air still going to ur exhaust, if its not chocking u should be fine, or replace the header if ur worried about it so much, oh and sinse ur not in CA, u can put something different like megan or other ebay headers, the down pipe should be the same sense they are just copy of DC
My downpipe was like that. I drilled holes and pulled the dents out with a dent puller. Then filled the holes up by welding. Unfortunately, I hit a huge pothole shortly after the repair and dented the same spots again.
my stock header was dented in the same place and it still ran pretty good. Im in school right now but I just got a call from my aunt saying that my megan showed up. I'll let you know if there is much of a difference
it will cause a 17.68 horsepower loss, and a 13.29 torque loss....give or take .43%, assuming a total dented area of 1.94 sq. in., and assuming the dent is in the 3rd quadrant of the header. If the interior cavity of the header was coated in sheep's blood before the install, the losses will not be as significant.....you did coat the interior cavity in sheep's blood, didn't you??!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts »</TD></TR><TR><TD CLASS="quote">it will cause a 17.68 horsepower loss, and a 13.29 torque loss....give or take .43%, assuming a total dented area of 1.94 sq. in., and assuming the dent is in the 3rd quadrant of the header. If the interior cavity of the header was coated in sheep's blood before the install, the losses will not be as significant.....you did coat the interior cavity in sheep's blood, didn't you??!!
haha very nice
</TD></TR></TABLE>haha very nice
I'm gonna assume thats a butt dyno result haha
</TD></TR></TABLE>I'm gonna assume thats a butt dyno result haha
Ahhhhhh. So THAT'S why my stock Si can't crack in to the 12's. I used fish guts instead of sheep's blood. My bad.
But in all seriousness, I don't think it would create any excessive back pressure that may cause damage. But it is ugly looking, and probably worth replacing sometime in the future.
</TD></TR></TABLE>Ahhhhhh. So THAT'S why my stock Si can't crack in to the 12's. I used fish guts instead of sheep's blood. My bad.
You could always coat it in axle grease inside. Supposedly it lubes up the passages for the air and picks up m4d p0wa in vtaK. Ask mattsnooz
</TD></TR></TABLE>You could always coat it in axle grease inside. Supposedly it lubes up the passages for the air and picks up m4d p0wa in vtaK. Ask mattsnooz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">
right....the air just slips on the lube. but you have to be sure to get the high-temp-high-grip axle grease, or it will just burn away and it will come out the exhaust (like in j-rome's thread with the plugs growing fuzz and exhaust spitting black junk.)
that's why you coat it in sheep's blood first....so the grease has something to hang onto. duh.....
</TD></TR></TABLE>right....the air just slips on the lube. but you have to be sure to get the high-temp-high-grip axle grease, or it will just burn away and it will come out the exhaust (like in j-rome's thread with the plugs growing fuzz and exhaust spitting black junk.)
Audrius Z
Oct 10, 2003 03:22 PM
