TO CUT CARBON FIBER?
Old Oct 22, 2007 | 11:57 AM
philosofy1's Avatar
Default TO CUT CARBON FIBER?
i just picked up a blank sheet of carbon fiber. i plan on using it on some interior parts and was wondering how well would it hold up once it came time to cut and shape.
i plan on using a scroll saw and a belt sander to smooth out the edges. if anybody has done this, how well did it hold up for you? any suggestions would be appreciated.
Old Oct 22, 2007 | 12:15 PM
philosofy1's Avatar
Default Re: TO CUT CARBON FIBER? (philosofy1)
BUMP
Old Oct 22, 2007 | 12:17 PM
Padawan's Avatar
Darth ModerVader
We don't need a bump every 18 minutes.
I've never cut CF, just worked on it with a Dremel, but I'd suggest using a very fine blade on the scroll saw. Other than that, you shouldn't have much of a problem, and if you lightly sand the edges they should have a decent finished look.
Old Oct 22, 2007 | 12:29 PM
philosofy1's Avatar
Default Re: TO CUT CARBON FIBER? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">We don't need a bump every 18 minutes.
I've never cut CF, just worked on it with a Dremel, but I'd suggest using a very fine blade on the scroll saw. Other than that, you shouldn't have much of a problem, and if you lightly sand the edges they should have a decent finished look. </TD></TR></TABLE>
i have fined blades that i use to cut steel plates that works good, i'll most likely use it on this. sweet, thanks!
u n v kenny
Paint and Body
Oct 10, 2007 01:57 PM
OMG THE GOGGLES
Jul 31, 2006 05:53 AM
jrbreaker85
Jul 13, 2006 04:47 AM
hatchedzex
Jan 22, 2005 01:28 PM
Squallie
18
Sep 19, 2004 05:36 PM
