Key Doesn't Work On Driver's Side After Being Locked Out
ok after about 4 hours of aggravation, my rigged up solution doesn't work ... here's a lil background info i locked myself out car, sheriff had to use some tool to open door now my key doesn't unlock the door, the lock works from inside though and with the electric lock ... i see the problem the little circle that's attached to the key hole on the handle isn't attached to the metal level bar, i had tried to tie it to it as a temp fix but that worked for less than 24 hours. what are the parts i need to replace? thanx in advance guys
ok i would tell you but then i would be teaching you how to break into other peoples cars so if u dont know its good for me lol get the pic and i will try to help u figure it out pm me if u want wen u have the pic
lol ok i get off work @ 6 and i have a 2 hr drive home so ill try to find something tonight ... thanx
