Condenser fan does not work.....need help troubleshooting
Old Oct 22, 2007 | 10:01 AM
smsimon's Avatar
Default Condenser fan does not work.....need help troubleshooting
The condenser fan on my radiator (94 honda accord lx) does not turn on when i turn my AC on. Is it possible to check the connector going to the fan with a multimeter to verify the motor on the fan is dead and not the connection?
Old Oct 22, 2007 | 05:02 PM
JimBlake's Avatar
Default Re: Condenser fan does not work.....need help troubleshooting (smsimon)
Sure, that's exactly what you should do. You'll want to check whether it's an open ground vs. a non-working hot lead.
Old Oct 22, 2007 | 05:04 PM
TheMuffinMan's Avatar
He knows where you live!
Wire the fan straight to the battery and see if it cuts on
If not it's toast
Old Oct 22, 2007 | 08:26 PM
aasaa666's Avatar
dont overlook the easy! start with the fuse, then work your way to the harder stuff.
Old Oct 23, 2007 | 04:13 AM
b_ron007's Avatar
does you a/c compressor kick in? is there a leak? is there freon in there? pressure too high....too low? does the a/c get cold?
we definitely need more to go on.
Old Oct 23, 2007 | 06:45 AM
smsimon's Avatar
Default Re: (b_ron007)
The AC kicks on but its not as cold as it used to be. I will try to hook the fan straight to the battery.
Kevonn Martin
Apr 26, 2018 08:03 AM
therest
Dec 5, 2016 04:40 AM
busted90accord
Apr 3, 2008 08:12 AM
albsgsr
Jul 29, 2005 05:08 PM
