how do you get a speed signal to the ECU?
Old Oct 22, 2007 | 07:28 AM
prettylew's Avatar
Default how do you get a speed signal to the ECU?
ok im curious and i cant figure it out, my car was converted by someone before me to OBD1, my question is this, how do you get a speed signal to the ECU with a cable drive VSS?? theres no wires comin out of it. soooooo. i dont know what to do.
Old Oct 22, 2007 | 07:47 AM
jlicrx's Avatar
Default Re: how do you get a speed signal to the ECU? (prettylew)
the speed sensor is on the gauge cluster where the speedometer cable goes in
Old Oct 22, 2007 | 08:04 AM
prettylew's Avatar
wow i feel like a moron. lol. thanks! do you know what color the wire is? so i can just run it straight to my ECU.
Old Oct 22, 2007 | 08:13 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: (prettylew)
Why???
It is already conected to the ECU. You do not have to touch that sensor for OBD1 covertion
Old Oct 22, 2007 | 08:25 AM
SIred91's Avatar
Rainman
Default Re: (Maxbore.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxbore.com &raquo;</TD></TR><TR><TD CLASS="quote">Why???
It is already conected to the ECU. You do not have to touch that sensor for OBD1 covertion</TD></TR></TABLE>
X2?
Old Oct 22, 2007 | 08:47 AM
prettylew's Avatar
well. someone didnt use a fancy wire harness conversion from rywire or anything, some honda tuning shop swapped it to obd1 like 7 years ago. idno.
how do i know if its already connected to the ECU?
Old Oct 22, 2007 | 09:37 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prettylew &raquo;</TD></TR><TR><TD CLASS="quote">well. someone didnt use a fancy wire harness conversion from rywire or anything, some honda tuning shop swapped it to obd1 like 7 years ago. idno.
how do i know if its already connected to the ECU?</TD></TR></TABLE>
You won't throw code 17...
Adam66085
Mar 25, 2016 10:07 PM
dpine
Engine Management and Tuning
Jan 13, 2009 06:41 PM
dem0nk1d
Jun 7, 2007 10:31 AM
darknessgsr00
Sep 16, 2005 05:42 AM
darrylwfarkas
May 19, 2003 04:34 PM
