Integra caliper???
Old Oct 22, 2007 | 05:14 AM
mach0's Avatar
Default Integra caliper???
I have a ej8 and looking to upgrade the front calipers...do the integras bolt right on or is there custom work???
Old Oct 22, 2007 | 05:19 AM
pdiggitydogg's Avatar
Holy ****...thank you for saying "integra calipers" instead of "gsr"!
Yes, integra calipers will bolt onto the ex/si knuckle. You will probably want to upgrade from the 7/8" MC that you have to the integra/civic abs 15/16 unit (or 1" if you can find it...but its not required for this swap).
Old Oct 22, 2007 | 05:21 AM
mach0's Avatar
THANKS...
Old Oct 25, 2007 | 07:55 PM
roastbeefrichie's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Holy ****...thank you for saying "integra calipers" instead of "gsr"!</TD></TR></TABLE>
Old Oct 25, 2007 | 08:09 PM
bmoua's Avatar
Yes, integra calipers will bolt onto the ex/si knuckle. You will probably want to upgrade from the 7/8" MC that you have to the integra/civic abs 15/16 unit (or 1" if you can find it...but its not required for this swap).</TD></TR></TABLE>
are you running a rear disc brakes on your ej8? if you are and havent upgraded to at least a 40/40 prop vavle then i wouldn't bolt up the teg calipers. When i did my rear disc conversion on my ej8, i threw on the the front gsr calipers at the same time and braking sucked. I locked up my brake constantly...
If your still running your drums in the rear throwing on the teg calipers shouldn't be a problem at all
Old Oct 26, 2007 | 10:56 AM
mach0's Avatar
Default Re: (bmoua)
not yet...i have the integra rear disc sittin in the garage...i dont ;look forward to puttin them on right now...i still have to get the brake lines and the ebrake cables...thanks for the information
chickenwing
Sep 9, 2008 03:50 PM
E.Honda
10
Jul 18, 2006 02:03 PM
MotorMouth
Apr 4, 2006 10:16 PM
xtrafastcivic
Jan 30, 2006 06:13 PM
143MYVTECEF
Jan 23, 2006 08:57 PM
