Anyone ever welded with Helium and DC-N for aluminum?
Old Oct 21, 2007 | 11:03 PM
RC000E's Avatar
Default Anyone ever welded with Helium and DC-N for aluminum?
What are the uses and purposes for this approach? I've heard you can penetrate alot of thickness with less amps. Anyone give me some insight?
Old Oct 22, 2007 | 01:27 AM
ManBearPig4silly's Avatar
It's for thick **** and it's not that hard to do. Run your gas flow about 3 times higher than normal and weld away. It's pretty self explanitory.
It's not going to be that useful for most car projects. I've used it on cyl heads before though.
Old Oct 22, 2007 | 12:19 PM
RC000E's Avatar
Default Re: (ManBearPig4silly)
Yeah, I remember RMF talking about it a while back. Gas flow 3 times higher...I dont' think my regulator goes that high...lol. I think he actually spoke specifically about cylinder heads.
So this method is mostly just to obtain penetration and add material, but it's not ideal though in terms of weld cleanliness or? Just trying to determine the down pro's and con's of it.
If you find yourself too pissed off at life to answer though, I understand.
Old Oct 22, 2007 | 03:21 PM
93supercoupe's Avatar
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">
If you find yourself too pissed off at life to answer though, I understand.</TD></TR></TABLE>
classic
Old Oct 22, 2007 | 03:26 PM
DESTROYER's Avatar
lol wowzers...
Old Oct 22, 2007 | 03:47 PM
RC000E's Avatar
Default Re: (DESTROYER)
lol....what....
Old Oct 22, 2007 | 04:03 PM
k24em2's Avatar
Your material has to be VERY VERY clean.
Like laboratory clean.
But other than that its just like normal welding. Move fast.
Old Oct 22, 2007 | 04:52 PM
RC000E's Avatar
Default Re: (k24em2)
Hmmm....sounds interesting. Guess I'll try that out on a junk head just to see what's up with it.
Do you use a green tungsten or a red?
Old Oct 22, 2007 | 09:27 PM
GTibunny16v's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm....sounds interesting. Guess I'll try that out on a junk head just to see what's up with it.
Do you use a green tungsten or a red?</TD></TR></TABLE>
Ive used this technique for welding cyl heads. I like a 3/32" brown tungsten (***** expensive) and I just round the edges of it. As you start to weld it ***** slightly. I keep my gas at 65 and use a gas lens with a #8 cup. Oh and I keep my amps at 100 and only go full throttle at the start to get a puddle started and then I back off to about 2/3 - 3/4 pedal. Remember MOVE FAST!
Old Oct 22, 2007 | 10:22 PM
RC000E's Avatar
Default Re: (GTibunny16v)
Man...this sounds exciting....lol. Gonna have to give it a shot, because I have access to heat treating for free.....so if I can get descent I could weld up some chambers
Old Oct 23, 2007 | 05:49 AM
I use red tungsten but other than that it's pretty much as described.
Jesus dude I gave you all the info you needed to know. You arn't a moron when it comes to welding as far as I can tell but you need to relax a little.
Just because I said it was self explanitory doesn't mean I meant it in a condesending way. Run helium 3 times higher than you would argon, weld with dcen as you would anything else on dcen......that's pretty much it man. I'm sorry if the simplicity of my answer confused you.
Old Oct 23, 2007 | 10:21 AM
RC000E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly &raquo;</TD></TR><TR><TD CLASS="quote">I use red tungsten but other than that it's pretty much as described.
Just because I said it was self explanitory doesn't mean I meant it in a condesending way. Run helium 3 times higher than you would argon, weld with dcen as you would anything else on dcen......that's pretty much it man. I'm sorry if the simplicity of my answer confused you. </TD></TR></TABLE>
LMAO....dude....haha.
Old Oct 23, 2007 | 11:35 AM
k24em2's Avatar
I use red sharpened to a point.
Old Oct 27, 2007 | 06:24 PM
TurboSI56's Avatar
Anyone care to explain some other mixtures like i've heard of hydrogen/argon mixes
Old Oct 27, 2007 | 10:01 PM
k24em2's Avatar
Default Re: (TurboSI56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI56 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone care to explain some other mixtures like i've heard of hydrogen/argon mixes</TD></TR></TABLE>
Only time you'd likely see an argon hydrogen mixture is if you're welding stainless sanitation piping.
weiRtech
Welding / Fabrication
14
Aug 3, 2007 02:57 PM
k0skesh
Honda Civic (2006 - 2015)
21
Jul 16, 2007 09:29 AM
sshaikh01
12
Mar 30, 2006 11:42 PM
tekstyle
19
Nov 25, 2005 06:44 AM
Mordeki
May 3, 2005 09:42 AM
