b20 not cranking
Old Oct 21, 2007 | 10:07 PM
obd1_crx's Avatar
Default b20 not cranking
im askin for a buddy of mine about this. he has a b20 swap in his crx. the injectors dont seem to be spraying. its getting fire and plenty fuel to the rail. we pulled them out and # 1 and 3 will squirt one time and thats it. what could be wrong with it?
Old Oct 21, 2007 | 10:20 PM
Fezzie's Avatar
Default Re: b20 not cranking (obd1_crx)
if its getting spark and fuel, hows the timing? what about gruonds are they good?
Old Oct 21, 2007 | 10:37 PM
obd1_crx's Avatar
getting good spark. the fuel pressure gauge reads 40lbs. the injectors just wont spray. we put my injectors from my civic in and it does the same thing.
Old Oct 21, 2007 | 10:44 PM
Fezzie's Avatar
Default Re: (obd1_crx)
and its not throwing any codes? check the grounds
Old Oct 22, 2007 | 11:30 AM
DC_RaceR's Avatar
Default Re: (Fezzie)
which obd injectors are you using?
Old Oct 22, 2007 | 02:30 PM
JDMB0YS's Avatar
damn does that b20 pull or what in the crx??
Old Oct 22, 2007 | 08:45 PM
obd1_crx's Avatar
Default Re: b20 not cranking (JDMB0YS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB0YS &raquo;</TD></TR><TR><TD CLASS="quote">damn does that b20 pull or what in the crx?? </TD></TR></TABLE>
dont know cause it wont crank. we tried his B16 injectors and my D16 injectors. mine were pulled straight off my car that day when i got there. both sets do the same thing. but its not throwing any codes. it just wont start at all.
Old Oct 24, 2007 | 03:30 AM
obd1_crx's Avatar
we still cant get the damn thing to run
Old Dec 19, 2007 | 03:32 PM
jozeff's Avatar
if its not cranking then its your distributor...get obd0 fron an da 90 91 integra..or low on battery..
Old Dec 19, 2007 | 03:36 PM
STREETWERKZ's Avatar
Default Re: b20 not cranking (jozeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd1_crx &raquo;</TD></TR><TR><TD CLASS="quote"> the injectors dont seem to be spraying. its getting fire and plenty fuel to the rail. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jozeff &raquo;</TD></TR><TR><TD CLASS="quote">if its not cranking then its your distributor...get obd0 fron an da 90 91 integra..or low on battery..</TD></TR></TABLE>
way to go! why should he replace a part that is working properly?
.:urbandc2:.
Aug 14, 2009 02:29 AM
rosner
Jul 20, 2009 08:49 PM
b20integrapower
Oct 17, 2006 03:43 PM
VitaminB20
Oct 25, 2002 01:19 AM
