Honda S2000 Honda S2000
sixth gear gone
Old Oct 21, 2007 | 09:14 PM
dgpgrove's Avatar
Default sixth gear gone
My 2000 S2000 has 47000 miles and recently I was going through the gears and could not get it in 6th. It doesn't grind or make any noise at all it just acts like a 5 speed. There is no gate for 6th. Does anyone have any ideas of what may have happened/broken?
All other gears work right without any grinding or poor shifts. I am stumped and my local Honda dealer is also.
Old Oct 21, 2007 | 11:25 PM
alex_belarus's Avatar
Default Re: sixth gear gone (dgpgrove)
u fucked ur gear what did u do to it and the dealer shoud replace it
Old Oct 22, 2007 | 02:10 AM
Srr's Avatar
Srr
i was at an autocross yesterday when a fellow s2000 driver said the same thing happened to him... he ended up replacing the 5th/6th syncro
Old Oct 22, 2007 | 05:05 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: sixth gear gone (alex_belarus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_belarus &raquo;</TD></TR><TR><TD CLASS="quote">u fucked ur gear what did u do to it and the dealer shoud replace it</TD></TR></TABLE>
SPEAK ENGLISH!!!
Old Oct 22, 2007 | 04:52 PM
dgpgrove's Avatar
Default Re: sixth gear gone (S2KILLA)
Thanks. I will pass that on to the dealer. I had wondered about that myself. Just seems to confirm my thinking.
Old Nov 19, 2007 | 12:10 AM
james2000's Avatar
Ive just lost 5th gear on my S2000 yesterday. Sounds exactly the same problem you had.
What was the problem with yours in the end? Was it the syncro? and how much did it cost to fix?
Old Nov 19, 2007 | 03:09 AM
2+2=5's Avatar
que?
Old Nov 19, 2007 | 08:58 AM
kojihan's Avatar
Default Re: sixth gear gone (james2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james2000 &raquo;</TD></TR><TR><TD CLASS="quote">Ive just lost 5th gear on my S2000 yesterday. Sounds exactly the same problem you had.
i read your post first and i thought this was by you too.
i was like he lost two gears in a day?
Old Nov 19, 2007 | 05:30 PM
RacerXI's Avatar
Default Re: sixth gear gone (kojihan)
Did either of you guys skip gears while shifting? You'll both end up loosing the "other" gear on that shaft too.
Old Nov 19, 2007 | 06:34 PM
Eddie99's Avatar
Default Re: sixth gear gone (RacerXI)
is it expensive to change the syncros? This happend to the secon gear on my brothers S2k
Old Nov 19, 2007 | 11:39 PM
james2000's Avatar
Yeah, I sometimes shift from 4th to 6th (to save time) - this shouldn't cause any problems though ?
Honda UK want £635.00 ($1270.00 US) just to take the gearbox out for an initial look !!!
Has anyone had this problem and then had it resolved? If so, what did it end up being?
Old Nov 20, 2007 | 12:28 AM
2+2=5's Avatar
skipping gear could cause "mushroom" syncro, and if that happens it would **** block the gear from sliding in and out.
some people save their gear by forcing it back in, sometime it works something you bent a shift fork
honda doesnt just sell syncro, they mate it with the gear
635lb sounds like the ballpark for it, there's tons to work plus you need to lower the motor just to get the darn thing out
james2000
Honda S2000
Nov 25, 2007 11:50 PM
S2K Luver
Honda S2000
10
Mar 22, 2007 08:33 PM
SpyLude92
Honda S2000
Jul 8, 2004 04:14 PM
jolt-tsp
Honda S2000
Jul 25, 2003 04:16 AM
