Emergency Help .. Actually Set a Fire under my plugs!!!!!
guys i really need yall help with this one please
I thought to service my odyssey van and i noticed for some reason power went a bit low while i was tryna start it.. so i thought one of my plugs went out so i pulled my plug cables one by one and as i did that all of them went out and all of a sudden there started a fire rite under my engine and my plugs were a bit wet .. maybe a seal leak? i put out the fire with water and tried changing out plugs but now only one plug is working. the plug cable is good but the power is not passing through plugs.. any idea wat i did? please respond !!!!
did you ever see a spark arch? if so, you probably caught some fumes on fire. And you might have killed your cap and rotor and such.
