Suspension & Brakes Theory, alignment, spring rates....
asr subframe bar and beaks lower tie bar?
Old Oct 21, 2007 | 05:11 PM
JDM_FRONTIN's Avatar
* B A N N E D *
Default asr subframe bar and beaks lower tie bar?
do they make or can you make an asr subframe bar and beaks lower tie bar work on a integra type r? thanks
Old Oct 21, 2007 | 05:34 PM
DSEA2's Avatar
Default Re: asr subframe bar and beaks lower tie bar? (EBAY)
whats the point, does the typr r not have enough subframe reinforcement for you?
Old Oct 21, 2007 | 05:46 PM
OMG THE GOGGLES's Avatar
Default Re: asr subframe bar and beaks lower tie bar? (DSEA2)
You don't need ASR with an ITR, ITR has different structure which is sufficient enough for the OEM 22mm bar.
Old Oct 21, 2007 | 07:02 PM
* B A N N E D *
Default Re: asr subframe bar and beaks lower tie bar? (OMG THE GOGGLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMG THE GOGGLES &raquo;</TD></TR><TR><TD CLASS="quote">You don't need ASR with an ITR, ITR has different structure which is sufficient enough for the OEM 22mm bar.</TD></TR></TABLE>
i appreciate your input but this does not answer my question....i dont care if i "dont" need it. it will serve the same purpose but it looks alot better and it will work with the 22mm bar....
so will it work or will i be having to modify it to work?
Old Oct 21, 2007 | 07:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBAY &raquo;</TD></TR><TR><TD CLASS="quote">
so will it work or will i be having to modify it to work?</TD></TR></TABLE>
ASR does not fit on the ITR subframe. They only support 94-01 RS/LS/GS(SE)/GSR [all same subframe]. The ITR subframe is different and reinforced, so the adaptors that the ASR come with will not fit flush. ASR makes a 32mm bar for the ITR, but no brace.
Happy?
Old Oct 21, 2007 | 07:32 PM
* B A N N E D *
Happy? </TD></TR></TABLE>
yes i am thanks bro....so i assume the beaks lower tie bar wont fit either correct?
Old Oct 21, 2007 | 08:01 PM
* B A N N E D *
k so i guess i will be spending money elsewhere
Old Oct 21, 2007 | 09:00 PM
yes i am thanks bro....so i assume the beaks lower tie bar wont fit either correct?</TD></TR></TABLE>
The Beaks is only a tie bar, so most likely you will be able to get it to fit right on. The problem with the ASR is that there is modifcation that needs to go on, and the pieces that come with it are machined specifically to the lower end chassis. The beaks kit has OVAL cutouts so even if the design made it a few MM off, you would still be able to get it to go on there. Reason they do the oval holes is because unlike a DC sports or cheaper made ebay, there is no threaded adjustability by means of turning and end and extending/compressing length.
Old Oct 22, 2007 | 10:10 AM
* B A N N E D *
thanks bro
Old Oct 22, 2007 | 10:27 AM
Donnie-'s Avatar
i think it would be pretty useless to use a beaks with an asr brace...looks like the asr gives well enough support for the lcas like th beaks would. even though the asr wont work on an itr like stated...i mean the above statement for other cars that are non type r
jefsese
Aug 13, 2008 07:45 PM
FormulaIntegra
Oct 17, 2007 02:41 PM
Spo0NFed E M 1
Suspension & Brakes
Jul 10, 2006 09:56 AM
thaiphob
Aug 24, 2003 10:10 AM
P1mpSlap
May 10, 2003 05:29 PM
