vtec not working on a DA
Old Oct 21, 2007 | 03:24 PM
beefjerky's Avatar
Default vtec not working on a DA
does anyone know how i can get my vtec to engage? its a b20 vtec..i hooked up everything right...it just wont pop..any help or suggestions?
Old Oct 21, 2007 | 04:51 PM
bara6075's Avatar
Default Re: vtec not working on a DA (beefjerky)
are you using an ecu with vtec like a p72, p28 ?
Old Oct 21, 2007 | 09:34 PM
beefjerky's Avatar
Default Re: vtec not working on a DA (bara6075)
its an obd 0 so i have a pr3 ecu thats a jdm b16 ecu and it is a vtec ecu
Old Oct 21, 2007 | 10:28 PM
St Jimmy's Avatar
* B A N N E D *
Hows your oil level? Speed sensor? Any CEL's?
You can always run a switched 12v to the vtec solinoid into the car and switch it on while driving. Just to test if the system actually works or not. If it works there then its something with the wiring or ecu making it not work... try to run a direct wire from the ecu pinout to the vtec solinoid if that doesnt work something is up with your ecu.
Old Oct 22, 2007 | 10:01 AM
antiJDM's Avatar
Default Re: vtec not working on a DA (St Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Hows your oil level? Speed sensor? Any CEL's?
You can always run a switched 12v to the vtec solinoid into the car and switch it on while driving. Just to test if the system actually works or not. If it works there then its something with the wiring or ecu making it not work... try to run a direct wire from the ecu pinout to the vtec solinoid if that doesnt work something is up with your ecu.</TD></TR></TABLE>
if you choose this method, make sure you have enough oil pressure to flip a vtec switch.
my advice is to chase wires, chances are that's where your problem lies. if that's not it start looking at things that are vtec specific to make sure everything is functional etc.
Old Oct 22, 2007 | 10:34 AM
DC209's Avatar
i had the same problem check your oil pressure and if not that its youre ECU thats what was wrong with mine
papinracing
Engine Management and Tuning
Mar 19, 2013 12:19 PM
tgjg19
Aug 17, 2009 07:41 PM
dat_flip
Apr 14, 2005 12:55 PM
showtymers619
Apr 14, 2004 11:00 PM
311
Oct 2, 2002 04:06 AM
