94 lx...battery wont hold charge
Old Oct 21, 2007 | 08:34 AM
e2000's Avatar
Default 94 lx...battery wont hold charge
-new battery
-alter. checked out fine
what else to check...grounds? fuses?
Old Oct 21, 2007 | 02:10 PM
e2000's Avatar
Old Oct 21, 2007 | 02:59 PM
fatboy1185's Avatar
Big Cat
Default Re: 94 lx...battery wont hold charge (e2000)
make sure the wires aren't rusty or whatever, then check the ground that goes to the block
Old Oct 21, 2007 | 03:08 PM
Bruce Banner's Avatar
did u do a load test?
Old Oct 21, 2007 | 07:46 PM
aasaa666's Avatar
check for any parasitic draw.
Old Oct 22, 2007 | 02:02 AM
e2000's Avatar
yea did the load test..thats good..I changed the whole ground cable on the neg. term. on battery..
parasitic draw ?
Old Oct 22, 2007 | 11:32 AM
e2000's Avatar
Old Oct 22, 2007 | 05:05 PM
JimBlake's Avatar
Default Re: (e2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e2000 &raquo;</TD></TR><TR><TD CLASS="quote">parasitic draw ?</TD></TR></TABLE>That means check for something that doesn't turn off like it should. Trunk lamp? Glovebox lamp? Amplifier or alarm that continues to draw power when it should be turned off? Bad brake pedal switch that leaves your brake lights on when the car's parked?
Old Oct 23, 2007 | 02:49 AM
e2000's Avatar
Yea none of that..Ill check anyway
Old Oct 23, 2007 | 05:14 AM
JimBlake's Avatar
Default Re: (e2000)
If you disconnect the battery overnight, and it still goes dead, then it HAS to be a bad battery. Even new ones can occasionally be bad.
But if you disconnect the battery & it doesn't go dead, then you know it's something in the car that doesn't know how to turn itself off.
Old Oct 23, 2007 | 08:38 AM
e2000's Avatar
yea ill try that...
Old Oct 23, 2007 | 01:16 PM
hondabum's Avatar
Default ?
how is the rubber in your alternator pulley ?
Old Oct 23, 2007 | 01:49 PM
e2000's Avatar
Good..
Old Oct 23, 2007 | 09:39 PM
bseriescrxsi's Avatar
Default Re: (e2000)
ok heres the thing may the alternator is not sending the battery power......this is how you test it
1. pull out a multimeter
2. put the negative on the negative part of the battery, then put the positive on that alternator where the wire plugs in that head to the battery take the reading
3 put negative to negative of battery and positive to positive of battery
if the readings are different follow the positive lead back to the fuse box, check the battery fuse, and check the wiring tightness
for steps 2 n 3 the car has to be running btw
Old Oct 24, 2007 | 06:18 AM
acriya79's Avatar
you can check your fuel light and distributor, sparkplug wires. my did the same thing as your to. try that.
Old Oct 24, 2007 | 09:36 AM
Default Re: 94 lx...battery wont hold charge (acriya79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acriya79 &raquo;</TD></TR><TR><TD CLASS="quote">you can check your fuel light and distributor, sparkplug wires. my did the same thing as your to. try that.</TD></TR></TABLE>
please tell me your kidding....ill leave it at that
Old Oct 24, 2007 | 01:37 PM
Honda-Master's Avatar
thy this
http://www.hondaaccordforum.co...m.htm
4dr_Noob
36
Nov 14, 2011 07:07 PM
rugimpy
Audio / Security / Video
26
Apr 20, 2011 07:28 AM
fumpster
Dec 5, 2007 11:24 AM
Quad-Damage
Jun 6, 2006 10:23 AM
tigueremalo
May 23, 2006 10:55 AM
