14's on SOHC All motor?
Old Jun 20, 2002 | 09:56 PM
MikeMAN's Avatar
Default 14's on SOHC All motor?
heya,
i was just wondering, what kinda mods would it take to run 14's with a stock 1998 EX, SOHC, all motor? i am sure it is a lot, and forced induction would be a cheaper way to get there...but i am just curious as I don't know a lot about All motor performance..
thanks,
mike
Old Jun 21, 2002 | 12:48 AM
Zero2Sixty's Avatar
Default Re: 14's on SOHC All motor? (MikeMAN)
All you would need is Higher compression pistons, a good set of rods, a knife edged and balanced crank, injectors, a fully built head, and then the basics like intake, header, exhaust, and an AEM EMS.
And that sould do the trick if not better.
And also a good driver.
Old Jun 21, 2002 | 08:10 AM
MikeMAN's Avatar
Default Re: 14's on SOHC All motor? (Zero2Sixty)
thanks man! i really do appreciate your help! i am not a newbie in the sport, but i am a newbie to this board so thanks for your help, and posting a useless reply like "why the hell would you want to do that? etc.."..but seriously..thanks
mike
Old Jun 21, 2002 | 01:12 PM
10seconds's Avatar
Honda-Tech User
you dont even need pistons and rods or crank
head package (cam, springs, etc.
I/H/E
street radials
skunk2 intake manifold
type r tb
and a really good driver or just use i/h/e, street radials, NOS
is this 98 sohc stock motor in a hatch or a coupe
Old Jun 21, 2002 | 08:08 PM
MikeMAN's Avatar
it is a coupe, so most likely need a little boost eh? something like the Civic Type R pistons? or what..i heard that the max streetable compression is 11:1..is this true?
thanks,
mike
BTW: does jackson make pistons for my car to up the compression?
thanks,
mike
Old Jun 21, 2002 | 09:50 PM
l's Avatar
l
it is a coupe, so most likely need a little boost eh? something like the Civic Type R pistonsthanks,
mike
you cant fit B series pistons into D series motors
well you could if you have $$$$$$$ buttt......
get p29 pistons (88-89 integra) pistons... they are quite nicely domed....
Old Jun 21, 2002 | 09:55 PM
MikeMAN's Avatar
thanks again guys! i am appreciating this new info...
just got my AEM CAI installed today, i likey.. :D
thanks again,
mike
Old Jun 22, 2002 | 09:45 AM
Black SVT's Avatar
Just a thought but,why?With motors being cheaper than a turbo kit and more reliable why not just do a b18c swap?
Old Jun 22, 2002 | 10:30 AM
highschooler's Avatar
you can get a gude head package and an ecu that allows for higher revs. combine that with i/h/e, a cluth and some slicks you should be anle to obtain easy 14's
Old Jun 22, 2002 | 10:31 AM
MikeMAN's Avatar
what would be a good ECU to get??
thanks,
mike
Old Jun 22, 2002 | 11:22 AM
bretx0r's Avatar
id say better gearing definately... but if thats not an option. ACT 6 puck clutch, some real slicks, I/H/E, bored throttlebody/ported intake manifold, thin headgasket, cam, valvetrain, and some tuning as well as gutting everything you can out of the car im sure thatd be good for 14's
[Modified by bretx0r, 8:23 PM 6/22/2002]
Old Jun 24, 2002 | 08:11 AM
Tsunami's Avatar
Default Re: 14's on SOHC All motor? (highschooler)
highschooler - Do you by any chance know of an online dealer that sells the gude head package besides Gude themselves? Reason why I ask is because the middle man sometimes has a better price than the manufacturer.
MikeMAN - Good luck on whatever you decide.
Old Jun 24, 2002 | 03:15 PM
Urban Business
Guest
Posts: n/a
Default Re: 14's on SOHC All motor? (IM ALL SHO)
max streetable compression is 12:1 on 93 octaine. shave head port and polish new cam lightened flywheel = 14's easy w/ bolt ons
Old Jun 24, 2002 | 07:40 PM
Audi A4's Avatar
Default Re: 14's on SOHC All motor? (TorteX)
stop wasting time and just get a turbo
Old Jun 25, 2002 | 11:17 AM
Trooper's Avatar
Default Re: 14's on SOHC All motor? (DRAG lll INTEGRA)
15.09 chiped p28, fpr, gude header, straight pipe, no name intake. this was done at carlsbad.
hondajav06
Sep 20, 2006 09:49 AM
hair_rice
71
Mar 7, 2004 12:06 PM
96civicracer_19
Mar 10, 2003 08:29 PM
x James Bond x
11
Sep 22, 2002 10:00 PM
Ted_Striker
28
Jul 7, 2002 07:58 PM
