Blown Headgasket?
Old Oct 20, 2007 | 06:58 PM
00civicsiboy's Avatar
Default Blown Headgasket?
So after a few trips to and from Alabama, I realized I have an oil/coolant leak somewhere on my motor. The motor is an lsvtec and I have already checked the vtec solenoid along with the distributor. I have traced the leak to the area between cylinder number 4 and cylinder number 3.
It appears that oil/coolant is leaking from the headgasket between these 2 cylinders.
Now for the questions..
The motor has 13k miles on it, it is possible for the gasket to give up already?
Could the head be warped even if I have never overheated?
Could the fact that the head has not been retorqued have anything to do with the leaking?
I appreciate any and all responses!
Thanks,
B
Old Oct 21, 2007 | 07:48 AM
Bump!
Old Oct 21, 2007 | 11:32 AM
Garage 808 Hatch's Avatar
a little more info would be helpful. boosted/na, are they mixing in the pan? etc. do a leak down test, and take off the radiator cap, if you get air bubbles in the rad, while the cyl is under pressure, its either a headgasket or a cracked sleeve
Old Oct 21, 2007 | 08:29 PM
Ill check tomorrow thanks for the info..Ill keep u informed.
Its an NA motor.
byrne_06
Jul 4, 2013 06:54 PM
JDM_Punk
Mar 26, 2010 04:08 PM
Fighterinsnatch
50
Jun 11, 2007 01:37 PM
iceman7329
25
May 22, 2007 07:24 AM
ITR1071
Dec 23, 2002 09:06 AM
