PLX m300 Wideband Install issue!!!!!
I'm having an issue with finding the right ECU pinout to connect the gray and white signal wires off my wideband. All of the write ups i found are for earlier civics with the D plug(D14 is what was suggested to plug into) But seeing as I have a 99-00 harness I only have the A,B and C connectors.
From this picture I am assuming I connect them to either C1 or C16. Is this correct? And do I connect BOTH the gray and the white to the same pin out?
TIA!!!
http://technet.ff-squad.com/wiring.obd2b.htm
Modified by enigma94 at 8:51 PM 10/20/2007
TIA!!!
Ok this is to hook up the Wide Band use pin D10 for the WB
Now if u want to use the Narrow band wire off the PLX
WHAT ECU AND are u OBD 1 or Using the factory ECU ??
D10 5 to the right of NUMBER 2 this is with the wiring harness plugged into the ecu looking on the back side of it. This is on the OBD 2 to the OBD1 harness
Yea, um a 99-00 harness does not have a D connector, thats why i provided the correct pinouts in the link. I'm using a OBD2B harness with a jumper to a OBD1 P28.
ef8sleepr
Jul 12, 2007 01:37 PM
hawj_boi_1
May 30, 2006 05:54 PM
rice crispies
Jul 5, 2005 08:07 AM
