how do you remove the airbag/steering wheel
Old Oct 20, 2007 | 02:52 PM
LaEzEnT's Avatar
Default how do you remove the airbag/steering wheel
I'm trying to remove the air first in order to remove the steering wheel.
My problem is that i can only find one torx screw which is the one on the left hand side behide the airbag Now where is the second torx screw?
thank you
Old Oct 20, 2007 | 03:01 PM
vinuneuro's Avatar
Default Re: how do you remove the airbag/steering wheel (LaEzEnT)
http://www.ntpog.org/mods/index.shtml
Old Oct 20, 2007 | 03:04 PM
LaEzEnT's Avatar
thank you for the help but i already been to that site it shows the 5gen
btw i'm asking for the airbag removal for a 4gen. I can't seem to find second trox screw which should be somewhere on the right side (it's hiding somewhere)
Old Oct 20, 2007 | 05:05 PM
LaEzEnT's Avatar
no one knows or they just dont want to help. The 4gen and the 5gen are different
Old Oct 20, 2007 | 09:04 PM
BB6DAVE's Avatar
i have it on a the service manual. if you need it. but did you try removing the cruise contol buttons.
I just replaced mine in the steering wheel and dash because i crashed my bb6. i used to own a 4th gen and own the electronic manual. let me know if that didnt help and if you need me to upload the images from the cd.
Old Oct 20, 2007 | 09:20 PM
1994PreludeSi's Avatar
Default Re: how do you remove the airbag/steering wheel (BB6DAVE)
There is actually a torx screw underneath a little "panel" on the right side of the steering wheel. I can't really remember exactly what it looks like but it is like a little square piece that looks like it can be pried off. I actually broke mine off because I installed an aftermarket steering wheel. Hope that helps.
Old Oct 20, 2007 | 09:35 PM
speedracer9k's Avatar
okay, there is a panel on the bottom of the steering wheel, remove the panel. disconnect the srs sensor (yellow connector). remove the torx bit on the left side of the steering wheel. turn the steering wheel 180 deg. and remove the cruise control buttons outer panel (it will break easily, be carefull). there is the other torx bit under that panel. remove the torx bit and then the air bag will come off. if your trying to remove the stering wheel, disconnect the rest of the sensors and clock spring and the steering wheel bolt. then you can remove the steering wheel. if it wont come off after you remove the center bolt, hit the outside of the sttering wheel with your hands to try to break it loose, it will come off. hope that helps you out
Old Oct 20, 2007 | 09:46 PM
LaEzEnT's Avatar
Default Re: (speedracer9k)
okay, so the second torx is behide the cruise control buttons outer panel. How would you recommend to remove the cruise control buttons outer panel? Cuz i have already scratch part of the steering wheel colum trying to pull it out but didnt even look like it's about to come off
Old Oct 23, 2007 | 05:54 PM
its tough, and it might break (mine did). you just have to pry it off. its the outter panel that goes around the cruise control buttons, it covers the buttons. good luck
Peruviann
Oct 6, 2007 08:55 PM
ek_will
Dec 29, 2005 07:45 PM
JibOnALib
Nov 25, 2004 05:18 PM
chbtek6
Oct 3, 2003 08:00 PM
Osman
Feb 10, 2003 01:20 PM
