crx swap WIRING question
Old Oct 20, 2007 | 10:59 AM
94stockhatch's Avatar
Default crx swap WIRING question
i would like to swap my b18c5 from my ek to my new crx hf,
other than mounts, shift linkage, spindels etc.
how do i wire this motor into that car.
is that any write up on this swap.
thnaks in advance
-noob
Old Oct 20, 2007 | 11:03 AM
ProSlow07's Avatar
Default Re: crx swap WIRING question (94stockhatch)
Just go to http://www.rywire.com and order the harness conversion, it's cheap and you already have a HF so you don't have to worry about the DPFI - MPFI conversion.
You'll need the tranny, hyrdo to cable conversion, ecu, axles, and I think you have to swap either your hubs or knuckles.
Hope this helps..
Old Oct 20, 2007 | 12:17 PM
Default Re: crx swap WIRING question (Deviant77)
http://rywire.com/store/8891-c...96909
is this what i get, after this is the harness just plug and play?
Old Oct 21, 2007 | 12:46 PM
any one?
Old Oct 21, 2007 | 01:42 PM
CO_RaceFab's Avatar
you still have to wire v-tech,knock sensor,second o2 and the oil pressure switch for v-tech but that is easy the jumper harness you order should have the provisions for those four sensors and the 4 wire o2 sensor then you just wire each sensor to the harness you bought with the instructions you really cant go wrong unless your a retard in which case your car should be at a reputable shop anyway instead of being hacked together for someone else to fix later which sucks
Old Oct 21, 2007 | 01:49 PM
DustinRose's Avatar
i am able to build that harness from scratch if you are willing to run OBD1, unfortunately i have not needed to create an OBD2 jumper yet, but i have the info for OBD0-OBD1
C-had340
Feb 5, 2015 01:39 PM
Beau Gotti
Jan 4, 2006 05:27 PM
Doh!
Jan 15, 2004 10:26 PM
The Brown Kid
Jun 2, 2003 12:20 PM
crx1856
May 30, 2003 03:29 AM
