h22 in to hatch need help
well this is my first post, i have around 4000 to spend i wana know if its possible to buy hatch shell and drop in an h22 with that budget if its been done before i would like to know what i have to go threw i need info. thank you in advance
the answer to your first post
READ THE FAQ
before you ask anymore questions, READ THE FAQ
4000 to spend, sure you can, it won't be easy, and will require you to do a lot of hunting around, and when you find that cheap *** shell you need to have cash in hand and a truck to pick it up, because everybody is looking for the same thing.
READ THE FAQ
most of your money is going to be spent on the engine and mounts, as well as all the parts and replacement fluids for that engine. you can probably pick up a shell that doesnt need alot of work for about a thousand maybe even less. I picked up a 94 eg6 w/ a D15 for $300.
https://honda-tech.com/zerothread/878010
tells what swaps are available and some pros/cons about it, plus the search button works good for many things!
BigD+Itsuki
Mar 16, 2002 09:00 PM
