Suspension & Brakes Theory, alignment, spring rates....
Suspension on DC2
Old Oct 20, 2007 | 06:38 AM
beastman@'s Avatar
Default Suspension on DC2
I hate being a nooob and asking for advice but:
Does anyone know what the OEM spring rates are?
I am upgrading my suspension and I really don't have anything to base my decision off.
I want to be lower, not slammed, and will be doing 99% of my driving on Massachusetts roads. I would like something that performs much better than stock.
My budget is about $500-$800, I am considering:
Koni Yellows+lowering springs
Tein basics
Any comments/suggestions would be great!
Old Oct 20, 2007 | 08:37 AM
Voyage34's Avatar
Default Re: Suspension on DC2 (beastman@)
ITR - 250F/250R (L/P)
GS-R - 200F/95R (P/P)
no idea on LS rates
Old Oct 20, 2007 | 09:32 AM
beastman@'s Avatar
Default Re: Suspension on DC2 (Voyage34)
Forgot to specify: 98 Integra GS-R
Old Oct 31, 2007 | 07:20 AM
beastman@'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">
How does this compare to 8k/6k ?
Old Oct 31, 2007 | 08:40 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">ITR - 250F/250R (L/P)
no idea on LS rates</TD></TR></TABLE>
LS rates would be the same as GS-R, as they use the same springs. I'm not sure how progressive they are though.
The progressive ITR rears range from about 140 lbs-in to 250.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">How does this compare to 8k/6k ? </TD></TR></TABLE>
1 kg-mm = 55.99 lbs-in
So 8 kg-mm is approximately 448 lbs-in and 6 kg-mm is approximately 336 lbs-in.
Keep in mind that a progressive rate spring will feel a bit softer overall than a linear rate due to starting at a lower initial rate and then ramping up as it compresses.
Old Oct 31, 2007 | 10:25 AM
beastman@'s Avatar
Default Re: Suspension on DC2 (Targa250R)
Thanks pro.
Old Oct 31, 2007 | 11:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Where are you getting these numbers? I've seen those and several other figures, as well.
Also, ITR rear springs are the only OEM springs to have a progressive rate. ITR front springs, and all non-R springs are linear rate.
Old Oct 31, 2007 | 11:33 AM
Targa250R's Avatar
be professional
Default Re: Suspension on DC2 (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Where are you getting these numbers? I've seen those and several other figures, as well.</TD></TR></TABLE>
I've seen other figures as well, but they all seem pretty close (246 for ITR springs, 212 or 217 for GSR, etc.). In addition, I'm not sure what the manufacturing tolerances are for whatever company is manufacturing the springs for Honda, so there could be several different numbers that are all falling within the acceptable range.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also, ITR rear springs are the only OEM springs to have a progressive rate. ITR front springs, and all non-R springs are linear rate.</TD></TR></TABLE>
Judging by the springs that I currently have in stock, that would be an accurate statement.
Old Oct 31, 2007 | 03:46 PM
Community Builder
I have my stock GS-R rear springs in a box along with ITR front springs... maybe someday I'll rig up a platform to put on top of a spring and load it up with known amounts of weight to see how much it compresses.
Old Nov 1, 2007 | 11:09 AM
brzrkr's Avatar
you can probably get koni+gc combo from a vendor on here, its like 780 shipped with no top hats
Old Nov 2, 2007 | 08:53 AM
beastman@'s Avatar
Default Re: (brzrkr)
I'm going to get PIC apex either P1 or P2. Jim at PIC recommended the P2 for a daily driver GSR, but someone on here said even the P1 would be super stiff. Anyone rocking these coilovers?
cheapskate
Suspension & Brakes
10
Oct 26, 2012 02:52 PM
NguyenDC2
Suspension & Brakes
17
Jun 5, 2007 04:13 PM
cloudx71
Sep 30, 2005 10:47 PM
1JDMDOMINICAN
34
Sep 26, 2005 06:05 AM
PahLok
Aug 3, 2005 02:05 PM
