Remote starter question
I am new to the forum and hoping you guys and girls can help me. I am look at adding a remote start only to a 03 ex v6. I plan on installing it myself cause I don't want to send it to a shop. I want it done correct with soldering connects and shrink wrapping them. But I need some insight.
question one: what is a good kind of system to get preferred a two way system that the fom tells me if the car is started or not.
question two: what modual do I need to fool the antitheft in the car so it thinks the car is in the car.
question three: any helpful hints or instructions (I will have a correct wire diagram while i am doing this to get the correct wires)
Anything made by Directed Electronics is good..
As for bypasses, you can use the 556U(where you will loose akey) or an xk05 or a 556H.
youll also have to go into the driver door for factory alarm disarm, the boot is a bitch to get through, but you can unplug it all from the fuse box and run the wire through, it adds like 25minutes on to the install..
