odd knock sensor problem
Old Oct 19, 2007 | 07:31 PM
b16a3delsol's Avatar
Default odd knock sensor problem
I posted this in the civic forum but no luck. My knock sensor only acts up when at idle. I can drive all day but the first red light I have to stop at the cel comes on and does whatever it does. Is this a common problem if so what is the fix. thanks
Old Oct 19, 2007 | 09:03 PM
Default Re: odd knock sensor problem (b16a3delsol)
somebody on this forum should be able to help me
Old Oct 21, 2007 | 05:45 AM
standbackimapro's Avatar
MY Friends b16 teg is doing the same thing, except it only comes on after he gets on it...
then it starts dumping fuel like crazy, i myself am trying to find help also
Old Oct 21, 2007 | 08:11 AM
Relic1's Avatar
new setup or stock?
have you checked for wiring problems?
have you replaced the knock sensor?
there rally isn't much else to check with a knock sensor, it's not a complex setup outside the ECU.
b16a3delsol
14
Nov 4, 2007 06:51 PM
zakkshaffer
May 22, 2007 01:29 AM
but
Sep 29, 2006 05:22 AM
Grnade
May 2, 2005 08:45 PM
d16y8coupe
Nov 22, 2002 02:09 PM
