brain storming
Old Oct 19, 2007 | 01:33 PM
91projectwidow's Avatar
Default brain storming
So im new to honda tech.......and well to honda's all together. Last week i picked up a 91 crx si as a daily driver for like 300 bucks. The car runs good and is fun to drive. So im thinkin im gonna invest 2500 dollars more in to it and make it a bit faster. So any suggestions? A few ppl said a b16 swap or a H22 swap...... would these kill the already good gas mileage im gettin out of the car?
thanks for any help or ideas
Old Oct 19, 2007 | 02:08 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
since i had my injectors balanced and put a new o2 sensor in, i'm getting 33-35 mpg avg with a b16 swap.
Old Oct 19, 2007 | 02:26 PM
jlicrx's Avatar
Default Re: brain storming (91projectwidow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91projectwidow &raquo;</TD></TR><TR><TD CLASS="quote"> So im thinkin im gonna invest 2500 dollars more in to it and make it a bit faster. So any suggestions? A few ppl said a b16 swap or a H22 swap</TD></TR></TABLE>the H22 swap is pretty complicated, even for experienced Honda swappers - involves cutting and rewelding the frame, as an example - probably can't be done for $2500 either - a B16 swap done right will cost you pretty close to $2500, if not more, all said and done and it is less money than an H22 swap
Old Oct 19, 2007 | 05:07 PM
grog's Avatar
Default Re: brain storming (jlicrx)
if you are truely concerned about gas milage you should realize that with more power usualy comes less gas milage. i think i'm down to 28 mpg in my GSR swap.
Maybe a D series will be a happy medium.
so what do you want more, and how much power are you looking for?
what are you D sries guy getting for mileage?
Old Oct 19, 2007 | 07:39 PM
JJ's civic's Avatar
Default Re: brain storming (grog)
want gas mileage and a little more power do a d15b easy swap and you get 52 mpg and 130 horse i'm planning one for my wife/
Old Oct 19, 2007 | 07:53 PM
gursh d's Avatar
if you get an h22 from an engine importer its going to be more than a $2500 swap. There's the tranny, axles, and mount kit, which would def put you over 2500. Unless you buy everything from an individual seller, might be cheaper, but I still doubt it.
clay0521
Jan 6, 2013 06:28 PM
speedyplumbing
10
Feb 22, 2010 06:10 PM
jlotz19
Jun 24, 2009 12:10 AM
99sibluehatchwitb16
Jan 20, 2006 08:29 PM
93formula
Jan 30, 2005 02:42 PM
