93 si swap?
its going to be a bitch to change from OBDO to OBDI
in my opinion. do like i did
get a 88-89 Integra ECU
4G civic or CRX Si distribuitor
inyector resistor
DPFI to MPFI conversion
and u are good to go.... the fuel map on the DOHC PG6 ecu its better than the 4G Si wich u can use also.....
inyector resistor
inyector resistor
inyector resistor
You won't see too much of a benefit running a non-vtec computer on a sohc vtec, but maybe I'm just biased because I converted to OBD-I. Seriously dude, it's not that hard. I built my own converter harness, and I have the complete guide to converting 88-91 Si and Dx to OBD-I. IM me if you need it. As for people who make the harness, Blown90Hatch does, I believe. And I've heard Kenji does as well.
