Spark Plugs stuck in head
Old Oct 19, 2007 | 12:48 PM
Ep1dem1c's Avatar
Default Spark Plugs stuck in head
Well bought a DX hatch a couple of months ago... I go to change the spark plugs and the spark plugs break off on cylinder one and four....
is there any way to get them out of the head without damaging it or taking off the head? thanks
Old Oct 23, 2007 | 02:38 PM
Ep1dem1c's Avatar
Default Re: Spark Plugs stuck in head (Ep1dem1c)
ttt
Old Oct 23, 2007 | 02:44 PM
Luserkid's Avatar
Easiest way is taking off the head.
Old Oct 23, 2007 | 03:00 PM
pdiggitydogg's Avatar
You could try a bolt extractor...with a long *** tap extension. That would be fairly expensive (the extension anyways)
Id just pull the head too. Few hours to do it right.
Old Oct 23, 2007 | 04:04 PM
hondamark35's Avatar
yeah i wouldn't want to try an extractor without taking the head off afterwards to clean out the chips that could have gotten in the chamber. the way these heads are designed that'll be your best bet to not break anything else. good luck man.
Old Oct 23, 2007 | 04:33 PM
raiden571's Avatar
take a pic. if you can. are you saying that the spark plug sheared off at the top of the threads?
Old Oct 23, 2007 | 04:34 PM
instrument's Avatar
thats scary, i bet they were the original spark plugs.
i did a tuneup on a friends car, it was a 94 buick something, still had the original sparkplugs with 230,000 miles on em....never had to use a breaker bar to get leverage on plugs before.
Old Oct 24, 2007 | 11:34 AM
Ep1dem1c's Avatar
Default Re: (raiden571)
yup broke off on the top of the threads...
Old Oct 24, 2007 | 06:34 PM
vrrodri's Avatar
Put some PB Blaster in there and let it sit for a bit...maybe with very long needle nose pliers you might be able to spin the top of whatever is left of the thread for the plug, depending on what you have to work with obviously.
busta7777
Feb 9, 2011 04:01 PM
mynumer1hater
Oct 5, 2009 11:47 AM
ITRFetish2000
May 21, 2004 07:18 AM
digitalcongo
Nov 12, 2003 07:49 PM
prjctCIVIC
Mar 18, 2003 04:06 AM
