FS: 5th Gen. Civic Guage Clusters
I have one cluster with a tach and one without. Both of these clusters came out of 5th gen. civics, and both were standard trans. The cluster with the tach reads 215,xxx miles and the other reads 229,xxx miles. Both are in working condition but the tach cluster's clear outer lens has been removed. It is not broken it just needs to be re-attached to the cluster, I believe some sort of adhesive will work fine. Also this cluster has a bulb floating around inside of it, I removed a bulb socket and the bulb fell inside. BO takes them.
89DXDann
Jun 4, 2004 11:38 PM
