ball joints
Old Oct 19, 2007 | 11:24 AM
Crx_Civic's Avatar
Default ball joints
what is the trick to getting the lower ball joint to come loose from the control arm on a 89 crx dx?
Old Oct 19, 2007 | 11:27 AM
CRX Toad's Avatar
Default Re: ball joints (Crx_Civic)
Hitting the LCA with a 3lbs mini sledge make sure you have the nut on your ball joint cause it you miss you'll mess up the threads on the ball joint.
Old Oct 19, 2007 | 11:42 AM
Ti Rider's Avatar
Default Re: ball joints (CRX Toad)
This is way easier to do and on the ball joint and LCA - Easiest Method.
Old Oct 19, 2007 | 12:17 PM
CRX Toad's Avatar
Default Re: (Dustin_Pierce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dustin_Pierce &raquo;</TD></TR><TR><TD CLASS="quote">This item works even faster http://www.sears.com/shc/s/p_1...joint</TD></TR></TABLE>
<FONT SIZE="5">NO NO NO NO NO</FONT> DON'T LISTEN TO THIS GUY YOU WILL SCREW UP THE BOOT ON THE BALL JOINT AND BE VERY MAD WHEN YOU HAVE TO REPLACE IT!
Old Oct 19, 2007 | 01:22 PM
EL Vap133's Avatar
Default Re: ball joints (Ti Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti Rider &raquo;</TD></TR><TR><TD CLASS="quote">This is way easier to do and on the ball joint and LCA - Easiest Method.</TD></TR></TABLE>
....and it is free.
Old Oct 19, 2007 | 01:33 PM
Crx Jimmy's Avatar
Default Re: ball joints (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
....and it is free. </TD></TR></TABLE>
It works great, be careful sometimes the wrench comes flying out after it pops
Old Oct 19, 2007 | 05:33 PM
Tyson's Avatar
wrench method only works for lower balljoint.
use a hammer.
https://honda-tech.com/zerothread/1912773
Old Oct 19, 2007 | 06:35 PM
Trakhor's Avatar
Torque Junkie
Default Re: ball joints (Tyson)
I'm with Tyson, a hammer is best because it works every time and if you choose a higher quality ratchet, like Snap On, then the proclaimed easiest methond is not always and option.
Old Oct 19, 2007 | 11:12 PM
welfarepc's Avatar
a 3lb mini is the way to go for sure as far as being the easiest....
i how ever, would prefer to put a crow bar or pry bar between the lower part of the nuckle and the lca and pry. the tighter you can wedge the pry bar or crow bar in the easier the BJ will pop. try stuffing the pry bar in and stomping it.. that ALWAYS works.
Old Oct 20, 2007 | 12:52 AM
Zaakro's Avatar
Default Re: ball joints (Trakhor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trakhor &raquo;</TD></TR><TR><TD CLASS="quote">I'm with Tyson, a hammer is best because it works every time and if you choose a higher quality ratchet, like Snap On, then the proclaimed easiest methond is not always and option.
I don't quite understand what you mean "if you use Snap-on this is not the best method." Are you talking about you using too good of tools that you don't want to break them? Have you ever broke a snap-on tool? In my life time (which isn't long by the way) I have only seen a handful of snap-on tools break and when the Snap-on guy come to the shop we give him the tool, he says "How the hell did you break that?" and he gives us another one for free.
Not even He-man himself can break a Snap-on tool
Old Oct 20, 2007 | 04:02 AM
Trakhor's Avatar
Torque Junkie
Default Re: ball joints (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">
Not even He-man himself can break a Snap-on tool</TD></TR></TABLE>
I was kinda hitting on two points there. One that the pic showed a crapsman ratchet (which i used to like until they started putting rocks in thier ratchet heads)
All of my ratchets, Snap On or Matco would never work in the way shown, the handles are simply too big and have rubber or plastic outer grip.
The other point is the improper use of a tool(5 points removed for the first one who make a tool joke) is not recomendable in my opinion, and especially not on a $120+ dollar tool.
Not even HeMan?....
Back when working on Honda's was my way of life, I broke Matco tools on a weekly basis. The Matco rep wrote a letter to headquarters recommending me for product testing.
Snap On isn't so bad, but our Snap On guy was a Strap On guy by night and well frankly he just freaked everyone out. But I managed to get a good little collection of Snap On tools, mainly ratchets, sockets and a set of wrenches.
I've broke 2 of the 3 Snap On ratchets I have a combined total of 6 times, 2 of those times the handle gave out the rest was the gear mechanism. That number is nearing 7 as CRX Toad notified me of an issue with the ratchet upon letting him use it a few months back.
So now that I've totally hijacked this thread, I'll give it back, and not recommend putting a big pry bar in there an jumping on it. That's asking for a injury whether personal or to the car, something about a cv boot and a tear comes to mind.
Old Oct 20, 2007 | 04:10 AM
jdmpnoy89's Avatar
http://www.harborfreight.com/c...45977
i have always used this gear puller, works most of the time. but if you do buy the harbor freight one i recomend that u change the bolts with higher grade ones, ive had the OG bolts snap and fly off.
mikekc99
Jun 13, 2007 10:42 PM
louevilhatch
Apr 21, 2007 09:06 PM
si 1
Dec 26, 2005 01:22 PM
MyDragCar
Dec 2, 2004 09:58 PM
squeaky
14
Aug 29, 2004 12:08 PM
